Re-map?Chip?New ECU? PLEASE HELP MY 2.7 BUILD IM DESPERATE
baurboy325
Hi all ,im abouit to stard my 2.7 build ,have the crank ,rods, pistons, gaskets, cam ,,etc etc all info necessary but am not able to find any info on re-maping,if its necessary ,chiping etc etc to get the most from the build will someone please point me in the right direction as i have not been able to get any help and am now desperate,regards,James.
Hi James, contact Ant at A-Tech on here, he makes chips suitable for the 2.7 and can tweek them for you. His own site is www.fastbimmer.co.uk
HTH
Charlie
HTH
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Ant
- Retired Team Member
- Contact:
thanks charlE30
5 off the shelf 2.7 chips for the most common hybrids, will get you running no issue, once she's run in perhaps dial her up to 100% with alive mapping session on the Emulator.
Email FTW
