central locking arrrrggghhhhhhh!!!
Mon Mar 29, 2010 8:37 am
No.
bimmer_e30
Mon Mar 29, 2010 10:11 am
Ok
Thanks for all your help it is much appreciated :D :D :D
gaszman
Fri Apr 02, 2010 3:04 pm
ok after cutting the red/black wire going into the door ( live feed ) then connecting this to the red/black into the cntrl locking relay still nowt but if i opperate the copper switches in the relay with my test lamp i can open the doors and close them ????
Fri Apr 02, 2010 7:57 pm
If the locks set and unlock from the relays, then the red/black wire is OK.
Use a piece of wire to briefly earth the yellow/blue or green/black on the locking ECU. Both should set the locks.
Use the piece of wire to briefly earth the green/blue and green/purple. This should unlock them
