Higher ampage fuse in lower ampage socket?
- E30 Zone Meets/Events Team
- Contact:
Go and buy the correct fuse.
If you put a higher rated fuse in it'll cause damage elswhere first if the origional fault is not fixed, not at the fuse.
BadDave
There must've been a reason for trhe fuse blowing in the 1st place.
Fix the problem, then fit the correct rated fuse
You could also "borrow" on of the 7.5A fuses for the front foglights from slots 29 or 30
yeah i was just after a tempory measure, then realised Halfords is open til 8!
The previous owner managed to bash the fogs apart so there's no fuses to nick from there. Got the 7.5's from Halfords now anyways, was just wondering if it was doable incase of emergancy is all.
- Brianmoooore
Absolutely not, under any circumstances! If the fuse blew there is a fault on that circuit, which may or may not reoccur.McDisco wrote:yeah i was just after a tempory measure
An acceptable option, in an absolute emergency, is to take a 7.5A fuse from another position, use that fuse in place of the blown one, and fit your larger fuse in the now vacant position, but this fuse must be replaced by a new 7.5A one at the earliest opportunity.
