diff question
mrLEE30
only REAL way is to open and look for the clutches. the two other options above will also work for a welded diff.DHFiS wrote:To be 100% sure the best way is to take the cast aluminium plate off and look at whats inside.
failing that look at the diff tag, an LSD will have an S in the tag before of after the ratio.
thanks will look at tags for s and try the methods the guys have put up cant see any wleding on diffsmrLEE30 wrote:only REAL way is to open and look for the clutches. the two other options above will also work for a welded diff.DHFiS wrote:To be 100% sure the best way is to take the cast aluminium plate off and look at whats inside.
what are lsd,s worth?
You will only see the weld once you have removed the backplate - the gears inside are welded together.lesward wrote:cant see any wleding on diffs
If you remove the backplate, you will be able to see the clutches anyway (or not).
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
gareth
the holes you can see in the 'spool' are huge in an open diff and you can see the gears inside. eg, if it looks different to that pic, it's not a LSD
