Having just fitted a alarm system with remote central locking i was wondering if there was a way I could get the interior lights to come on when I unlock the car as opposed to them coming on only when I open the door?
I have read something before about a light delay module that sits near the central locking computer do I need one of these of is there a way I can do it without one of these?
Interior light question
- **BANNED**
My interior light delay units work the other way round,lock the car and walk away and all your mates start yelling that the interior light is still on....then it fades out....
Youth is wasted on the young.
pac1982
Hmmm seems to the OE unit does the reverse of what I’m after, don’t suppose any clever people know of an easy solution to gain the desired effect??daimlerman wrote:My interior light delay units work the other way round,lock the car and walk away and all your mates start yelling that the interior light is still on....then it fades out....
There was some fell adapting the OE unit to give a gradual delay in the states and posting them over here. That was on the old zone though and he hasnt been on in an age before that! It can be modified yourself but thats beyond me.
Sanchez
Does your alarm trigger the hazard lights?pac1982 wrote:Hmmm seems to the OE unit does the reverse of what I’m after, don’t suppose any clever people know of an easy solution to gain the desired effect??daimlerman wrote:My interior light delay units work the other way round,lock the car and walk away and all your mates start yelling that the interior light is still on....then it fades out....
If so change the wiring so that it give power to the interior lights instead, hey presto when you arm or disarm the alarm the interior lights will light instead of the indicators.
yes you can do this first you need the said module plus a switch/relay that can take the signal from your alarm to make the module work but the light will go out after a set time also it will not be a simple plug in and play setup as far as i can tell
- Brianmoooore
If you have an interior light delay module fitted, it should be possible to achieve what you want by connecting the unlock pulse output of the alarm to the door pin input of the delay module. You would need to fit a blocking diode in the wire, and another one in the existing door pin wire.
pac1982
Hmmm ok then first step is o fid one of these interior light delay modules, are thy expensive, still availble from the stealer etc??
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
- Brianmoooore
Delay modules aren't that common in the UK, but they're not exactly rare either.
Try an ad. in parts wanted.
Same module was used in some E28 models as well.
