Are there any options for converting the single coil with distrubutor to multi coil distributorless ignition, whilst still using the stock ECU?
Now the stock distributor only sends the spark to the correct plug, it's the ECU alters the timing from the various sensors, plug lead sensor (cam position), speed and position sensor on the front of the crank, AFM (air temp and load), water temp sensor, TPS.
Is there a bolt on computer that uses the stock speed/position crank sensor on the front of the engine to distrubute the spark to each of the 6 coils whilst leaving the stock ECU to sort the timing?
edit - I've learned to spell distributor and at £160 I must have read a quote for two dizzy caps
