325i not starting
D17LLY
Thu Dec 31, 2009 6:58 pm
All rest has been done there is 12v from the injectors Put meter on the red/White wire no corrosion from the plug below the intake manifold.......
FLEX
Sat Feb 20, 2010 8:55 pm
I have the same problem but ive traced the problem to the injectors i think.
I have 12v on the red white with ign on AND i also have 12v on the brown white with the ign on.
When i crank neither wire pulses or loses power, it just drops to about 9v and stays there till you stop cranking, is this right??
Sorry to hijack your thread :wink:
Sat Feb 20, 2010 9:26 pm
You are unlikely to detect the injector pulses on the brown/white wire with a meter when cranking. The pulses are very narrow at cranking speed, and are unlikely to be seen against the varying reduced cranking voltage (which pulses each time a piston goes over TDC) and with the slow response of the average digital multimeter.
FLEX
Sat Feb 20, 2010 9:56 pm
Was thinking that but i thought id see something.
I will satrt a thread and give more info.
Thanks.
