Fitting a Z3 diff
Y_Cymro
Tue Dec 29, 2009 10:13 pm
To go with my M50 conversion I have a Z3 lsd to replace the standard diff in my 316i Touring. Is the new diff a straight swap?
Kos
Tue Dec 29, 2009 10:15 pm
pretty much yes
if its of a ZM , you'll need to swop the put put flanges for some e30 ones to mate up with your drive shafts
www.pukardesigns.com
IG Pukar.Designs
Y_Cymro
Wed Dec 30, 2009 12:20 pm
Kos wrote:pretty much yes
Sorry, I should have said it's from a Z3 2.8 with torsen diff.
So it should bolt straight on without changing flanges?
Jonsku
Wed Dec 30, 2009 12:46 pm
Yes it should be direct bolt-on, if flanges are different (prop- / driveshaft) you can swap them from your e30 diff.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
N00b
Wed Dec 30, 2009 12:50 pm
Is the Z3 diff a straight swap, or do you put the Z3 internals into an e30 case?
Wed Dec 30, 2009 1:08 pm
N00b wrote:Is the Z3 diff a straight swap, or do you put the Z3 internals into an e30 case?
Straight swap. Z3 uses an 30 type rear beam.
N00b
Wed Dec 30, 2009 1:20 pm
Good to know.
Does this mean the CWP are interchangeable between Z3 and e30, as if it does then it looks like a Z3 diff would be a good choice as it should be in better condition than an e30 item.
Y_Cymro
Wed Dec 30, 2009 1:33 pm
Good to know.
I believe that the Z3 uses a medium case - hence my question whether the complete diff is a straight swap. A problem you might have is that the Z3 has a direct top gear so the diff ratios tend to be too high if you are using an E30 overdrive top gearbox.
Y_Cymro
Wed Dec 30, 2009 1:35 pm
Thank you all for your help.
Wed Dec 30, 2009 1:37 pm
Z3 diff fits straight on, but with the E30 gearbox and 1.6 M40 engine you'll need a calendar for 0 - 60 times!
N00b
Wed Dec 30, 2009 1:46 pm
Surely you could change the CWP for a more suitable e30 part to give a more desireable ratio?
Wed Dec 30, 2009 6:51 pm
N00b wrote:Surely you could change the CWP for a more suitable e30 part to give a more desireable ratio?
Then you have to set up the shims and crush tube. Generally reckoned to be a specialist (=expensive) job
N00b
Wed Dec 30, 2009 9:57 pm
Ah, my bad. I was under the impression that the actual workings of the LSD remained intact and all that was needed was to remove and change the final drive cog. Out of curiosity, what kind of money are we talking to have this done? Ballpark figure will be enough.
Wed Dec 30, 2009 10:16 pm
You'd be better off selling the Z3M diff to someone who's doing a m5x conversion, for which it's ideal, and sourcing a diff with a more suitable ratio, or better still, binning the 1.6 M40 yourself!
WeBuyAnyCar
**BANNED**
Wed Dec 30, 2009 10:30 pm
On this topic I hear e36 compacts have the same rear setup as an E30 so you can use the rear arms in 5 stud conversion and the diff on the e30.
Do the 318ti use a 4.11LSD?
N00b
Thu Dec 31, 2009 12:23 am
WeBuyAnyCar wrote:On this topic I hear e36 compacts have the same rear setup as an E30 so you can use the rear arms in 5 stud conversion and the diff on the e30.
Yeah I've heard that the compact uses the same rear suspension setup as the e30. Is the front end also e30?
Kos
Thu Dec 31, 2009 2:11 am
no
IG Pukar.Designs
WeBuyAnyCar
**BANNED**
Thu Dec 31, 2009 4:19 am
So kos the rear end is the same yer.
But do they make a 4.11 LSD for them
Kos
Thu Dec 31, 2009 4:36 am
same is 99% e30
LSD's are available but it depends what size diff case you want
use the search function, you'll find out all that you need to
IG Pukar.Designs
Rusty_McRusty
Thu Dec 31, 2009 11:27 am
The 4.1 LSD on mine was sourced from the US by the previous owner, I believe it's a small case off an E30. Original owner of the diff was on here, tom_stickland. The diff works well with the M44, gives useable performance in the lower gears and is (obviously) livlier than the 3.9 that came with the car. Certainly wouldn't want to go any lower than 3.9 on mine, on a 1.6 the problem will be magnified somewhat!
Thu Dec 31, 2009 12:39 pm
At a guess i would say an LSD was an option (but im still doubtfull) on 318ti compacts but i have never seen or heard of on fitted.
They normally come with ASC.
penton08
Thu Dec 31, 2009 1:50 pm
as above... and normally 318ti's will have a 3.38.1 diff.
WeBuyAnyCar
**BANNED**
Thu Dec 31, 2009 4:12 pm
Whats ASC
Kos
Thu Dec 31, 2009 5:57 pm
penton08 wrote:as above... and normally 318ti's will have a 3.38.1 diff.
it depends if they are M42 or M44 powered
ASC = traction control
IG Pukar.Designs
