Instrument cluster not universal?
TonyWilson
Thu Sep 10, 2009 6:36 pm
My rev counter goes crazy when i put the boot down, it goes off the counter then starts to swing back and forth probably wondering how a 1.6 litre can accelerate the way it does lol.
Does this mean i need to get an instrument cluster from a 325?
kam-325i
Thu Sep 10, 2009 6:38 pm
There is a coding plug fitted to clusters. you need to swap it for the one that is in your old cluster.
Ziggy
Nope, just the coding plug :thumb:
12345kevin
presumably the cluster is from a 4 cylinder car and you have a 6 cylinder car ? If this is the case you'll just need the coding plug that goes in the front of the cluster :D
Ziggy
:lol: Think that covers it?!
dazleeds
old skool raver
old skool raver
Thu Sep 10, 2009 6:39 pm
if your cluster has a code plug in the front then you should only need to change the plug
if your cluster dosent then yes youll need the full cluster afaik
www.oldskoolfantasy.co.uk
12345kevin
Thu Sep 10, 2009 6:40 pm
Lets all post together :mad:
kam-325i
4 post's at the same time !!!!! :cool:
beemerbird
Thu Sep 10, 2009 6:41 pm
kam-325i wrote:4 post's at the same time !!!!! :cool:
And for once, everyone agrees with each other :eek:
:wink:
dazleeds
old skool raver
old skool raver
lol
hope that helps :D
TonyWilson
Thu Sep 10, 2009 6:49 pm
Unanamous verdict lmao, thats what i love about this site quick response and with the correct answer.
Yes your correct i've gone from a 4 clinder to a 6 cylinder but i never got any coding plug so i might have to steal one ;-) lol
Cheers guys
Chris00
Fri Sep 11, 2009 11:09 am
What one is the coding plug? :?
Chris00
Fri Sep 11, 2009 11:27 am
So the old ones and the new ones arnt interchangeable? What abot the fuel guage coding plug? ive got a cluster out of a S.A e30 with the long range fuel tank and the guage reads the wrong amount compared to the U.K guage
fuzzy
He who sleeps with "Gingers"
Fri Sep 11, 2009 9:11 pm
my guages used to read slightly fast when i stuck in my 4 pot conversion . other than that there was no jumping around or erratic reading.
Fri Sep 11, 2009 9:17 pm
fuzzy wrote:my guages used to read slightly fast when i stuck in my 4 pot conversion . other than that there was no jumping around or erratic reading.
Exactly! With the wrong coding plug, the readings should simply be wrong, not erratic.
