induction kit
fiky
Sat Aug 22, 2009 11:22 am
hi can anyone tell me wre can i mount the airflow meter after cone filter is put on and also were is the best place to position the cold intake pipe...cheers
DHFiS
Sat Aug 22, 2009 11:27 am
why are you changing the standard set up?
m_jermyn
Sat Aug 22, 2009 11:34 am
just put a k&N panel filter in the standard airbox mate, works better then a cone...
fiky
Sat Aug 22, 2009 11:46 am
looking for sum intense sound under the hood guys
m_jermyn
Sat Aug 22, 2009 11:53 am
drill a few holes in the side of the airbox then and save some money
leeparkes
Sat Aug 22, 2009 1:44 pm
The standard BMW air box is very well designed to give the most power,if you want to stick with the cone filter for the noise i would try and shield it from the under bonnet heat or you 'will' lose power!
you can get heat shields off e-bay or knock your own up.
DHFiS
Sat Aug 22, 2009 11:09 pm
fiky wrote:looking for sum intense sound under the hood guys
and your engine is a .............?
DHFiS
Sun Aug 23, 2009 6:21 pm
"ive got a 320i"
m_jermyn wrote:drill a few holes in the side of the airbox then and save some money
