looking to ocnvert my early chromie to tech2 spec, i know i have to change the fron panel for the later ones, do i specifically need a cabby panel or will the saloon/coupe panel fit? same goes for the tech2 bumpers aswell? also what do i have to do to fit the rear bumper? any tips ony converting or links to threads would be appreciated
cheers
Converting from tech1 to tech2
SeymourCake
Check out my thread mate...
Should tell you what you need to know
mrLEE30
all is covered here.
http://www.r3vlimited.com/tech/bumper/bumper1.htm
the only main difference is you will not need to modify the length of the rear bumper as shown in the article.
This is because the tin tops have a different rear wheel arch profile between pre and post face lift (to allow more legroom in the rear seat apparently??), but as far as i know the cabs all had the later rear wheel arch profile irregardless of the cab model thus the tech 2 should fit on, however the mods to the front metal valance and mounts still are the same as Jordan's article.
mrlee
mrlee
