cam wear
mattandjazze30
Thu Aug 06, 2009 5:31 pm
can bad cam wear be the cause of my car over fueling and back fireing? as i have changed every thing now and it still runs terrible. im thinking if its that worn the valves could be staying open to long hence the over fuel?? i the cam is badly worn and the followers are knocking im running out of ideas now guys :(
i have changed
fuel pump
fuel regulator
plugs
leads
crank senser
coil
ecu
and still no joy!!!
asmith88
Thu Aug 06, 2009 5:46 pm
have you checked the co?
1990 brilliant red 318 is
mattandjazze30
Thu Aug 06, 2009 5:55 pm
co? how can i check it?
SkyRocketeer
Fri Aug 07, 2009 9:08 am
Cam wear would shorten the duration and lift of the valves, as it's the lump in the cam that opens the valve - less lump = less valve openage.
To check the CO get it into a garage with a tester. In fact, find a decent enough specialist and let them diagnose it for you..
