need help urgently for rear wheel arches
Basically i got intouch with a company called archenemy to get my arches rolled they came out and i got some bad news they said that the couldnt roll my arches as they had been done previously and not a good job at all and one arch is totally knackerd what i need is a gr8 person to grind the arches for me and still keep my orginal lip can anybody pls help me .......
basicly yes there is still the lip but not enough to get rolled without ruining the arch....kevin316i wrote:What do you mean by 'totally knackered'? Is the joint between the inner and outer arch damaged / broken away?
And from the constant rubbing issues it kept eatin away at the arch and pulling it down ....j4gz wrote:basicly yes there is still the lip but not enough to get rolled without ruining the arch....kevin316i wrote:What do you mean by 'totally knackered'? Is the joint between the inner and outer arch damaged / broken away?
