the cars not currently driveable so is there something i would have on the car that would tell me if it was abs or not??? i have a 318is and wanna get new brake lines.
thanks
how do i tell if i got abs or not????
treeseries
currently without a BMW ðŸ˜
gareth
seconded on both of the above comments.
the ABS unit is hard to miss, it has a plastic cover with ABS written on it (on all i've seen anyway) and a whole load of brake pipes going in and out.
treeseries
yes its discs all round, so its definately 6lines i need?
yep, 6 lines for sure.
2 for the front, 2 from the body to the rear trailing arms, and 2 from the other end of the hard pipe on the trailing arm to the rear calliper.
the abs / no abs is missleading.
cars with rear drums only need 4 lines because the rear wheel cylinder inside the drum is rigidy fixed to the rear arm so it doesnt need a flexy there unlike a calliper which needs to move to work.
cheers,
harry
harry
marley_uk1
what are a good ones that dont cost the world?
