Trolly Jacks: What do you have?
The time has come to invest in a worthwhile trolly jack Smile
I have looked at several and am happy to spend upto £100
I also dislike the gear type that most seam to have now adays to let them down, prefering the hydrolic type (no gears)
The one I like the most of the ones I have looked at is this one at £92
http://www.machinemart.co.uk/shop/produ ... olley-jack
Any thoughts and examples of what you have appreciated Smile
many thanx
Andy
many thanx
Andy
i have a arcan 2 tonne aluminium trolley jack, came from costco best money i have ever spent, it was about £75 but that was a couple of years ago, same as this one but mine is all silver
http://cgi.ebay.co.uk/Arcan-Aluminium-J ... 7C294%3A50
- Brianmoooore
Unless you specifically need the ultra low minimum height and the light weight, then I wouldn't consider this one. It has an extremely limited maximum lift, not very great lifting capacity, and I expect would be easily damaged.
The semi professional 2 tonne or 3 tonne jacks will be a much better buy.
SPADGE
That ally one would make a nice ornament if you don't intend using it much.
Otherwise as Brian said get yourself a decent heavier duty one preferably with a 'quick lift'
MachineMart are expensive!
What about this one
http://www.cromwell.co.uk/KEN5037100K
At work we use a lot of Kennedy tools and havn't had a problem yet!
What about this one
- Bavarian_Autotech
who needs to lift more than 1.25 ton unless they're working on commercial vehicles ?Brianmoooore wrote:Unless you specifically need the ultra low minimum height and the light weight, then I wouldn't consider this one. It has an extremely limited maximum lift, not very great lifting capacity, and I expect would be easily damaged.
even if you had a brand new 7 series you'd never need to lift more than a ton or so.
fuzzy
my halford jack has lasted me well for a few years now. does the job well for diy and home use.
http://www.halfords.com/webapp/wcs/stor ... _langId_-1
- Brianmoooore
It's the limited lift that's the problem with these cheap jacks. I've got three of these or similar jacks in the workshop, and they can barely lift an E30 wheel off of the ground.In reply to Bavarian_Autotech, you don't want to be operating anything as safety critical as a jack at anywhere near its maximum capacity! 300% safety margin is good!fuzzy wrote:my halford jack has lasted me well for a few years now. does the job well for diy and home use.
SPADGE
In general trolley jacks with a lighter capcity tend to have a narrower and shorter wheel base and tend to be a lot less stable than ones designed to lift heavier weights.
Can you view this thread without having to register?
http://www.soarerworld.com/forum/showthread.php?t=26692
Perhaps I am old fashioned, but I don't really get underneath cars until its on axle stands...I then leave the jack tweeked up enough so that its not taking any weight, but so it should hold if something goes wrong.
I have a 2 ton clarke trolley jack had it years, has lifted many things including a 28ft steel container weighing in at 4/5 ton
would like a newer one that raises quicker
Well as you may know im too poor for a trolley jack or anythign expensive really so i have a ford scissor jack bm jack porsche scissor jack and a clarke 3tonne bottle jack as well as a 15 tonne bearing press
I've got a similar Argos jobbie. Your right, it takes a lot of effot to jack up a car.Brianmoooore wrote:It's the limited lift that's the problem with these cheap jacks. I've got three of these or similar jacks in the workshop, and they can barely lift an E30 wheel off of the ground.In reply to Bavarian_Autotech, you don't want to be operating anything as safety critical as a jack at anywhere near its maximum capacity! 300% safety margin is good!fuzzy wrote:my halford jack has lasted me well for a few years now. does the job well for diy and home use.
Ollie_bwoii
My Pap has a 4 post lift so I would use that if I had an E30!
I have always assumed the 'max weight' figure for the jack is the save working limit not the failure point but I use axle stands anyway.Brianmoooore wrote: you don't want to be operating anything as safety critical as a jack at anywhere near its maximum capacity! 300% safety margin is good!
this is a test from about 4 years ago but I don't suppose things have changed too much
http://www.autoexpress.co.uk/products/p ... jacks.html
hope it helps
hope it helps
jamie325isport
I use one of these, a little bit more than your £100 budget though. If you have a lowered car this is perfect, and it goes fairly high. I didnt pay as much as whats this website want, a friend of mine got it through his company.
http://www.holden.co.uk/displayproduct. ... de=094.516
I've got a clarke 3 ton and I've had it for about 5 years. It's brilliant. Very heavy though but an excellent jack. Agree with jules, quick lift for initially making contact would be useful.
I've used mine to the max and have had no complaints at all.
http://www.machinemart.co.uk/shop/produ ... sion-jacks
I know this will come under the jacks that are too light - but I thought it was a bargain and it fits in it's own box in my boot.
2 ton jack
two axle stands
2 wheel chocks
just under 32 quid
http://www.screwfix.com/prods/66742/Van ... -Combi-Kit
2 ton jack
two axle stands
2 wheel chocks
just under 32 quid
- Brianmoooore
I have a four post lift - cost me £100. The cheap jacks are for use on the ramp.Ollie_bwoii wrote:My Pap has a 4 post lift so I would use that if I had an E30!
Demlotcrew
I cant say that i agree with many posts in this thread, ive had one of these so called "cheap" ali jacks for about a year now and ive had no problems at all, infact its the best £100 i spent last year!
Lifts anything and its very strong, i dont see it breaking any time soon.
Lifts my E30 racer half a meter off the ground, and here is a pic of the E46 with both wheels off the ground and the jack is only about half way up.
I say but it you wont regret it! I also love the fact its only 20kg, ideal for track days and race trips.
- Brianmoooore
Jack in the OP has a lift height of 376mm. That would hardly lift an E30 rear wheel off of the ground, if used under the beam bush bracket.
SteMarsden
I have the same jack from Machine Mart (which if you buy on a VAT-free day is VFM......
However, I had to return the first one as one of the small wheels failed and all the bb's fell out! I was jacking a car up on a small slope though.
All changed with no fuss and its replacement is fine!
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
2011 VW Passat Est
Demlotcrew
Ive got this jack;Brianmoooore wrote:Jack in the OP has a lift height of 376mm. That would hardly lift an E30 rear wheel off of the ground, if used under the beam bush bracket.
Jacks would be designed with a larger factor of safety and therefore could lift much heavier weights than its rating without reaching its safe working stress. Theoretically there should be no need for anything over a 1 tonne jack. However larger jacks are more stable and generally give a higher lift.
If it was my choice, I would get a 2 or 3 tonne with a high lift height. Very hard to work under a car when its too low.
zaust
- Zone day release
I have the mother of all jack's. (as some zoner's have seen) 50 ton limit
Will put a pic up later. Can't remember the make, but it is designed to lift lorry trailer's with full load's, when they need a tyre change at the road side. (or support your house whilest underpinning)
Unfortunatly it can't be slung in the back of the motor and hauled around easy.
- Contact:
Minimum height 145mm,Rodderz wrote:MachineMart are expensive!
What about this one
Thats not a very wise spend for somebody with an E30!
same as mineDemlotcrew wrote:Ive got this jack;Brianmoooore wrote:Jack in the OP has a lift height of 376mm. That would hardly lift an E30 rear wheel off of the ground, if used under the beam bush bracket.
SPADGE
Not very good for lifting on a boggy surface though if i recall Marczaust wrote:I have the mother of all jack's. (as some zoner's have seen) 50 ton limitWill put a pic up later. Can't remember the make, but it is designed to lift lorry trailer's with full load's, when they need a tyre change at the road side. (or support your house whilest underpinning)
SPADGE
The one in the original topic posters link says max saddle height 376mm so that won't lift your e30 half a metre off the ground.Demlotcrew wrote:I cant say that i agree with many posts in this thread, ive had one of these so called "cheap" ali jacks for about a year now and ive had no problems at all, infact its the best £100 i spent last year!
They may be ok for occasional use or for track days etc...but not for heavier duty work where a cheaper sturdier alternative would be a better buy.
