Tappets
nuttyp
Thu Apr 30, 2009 1:18 am
I have adjusted my tappets to specified limits, but car still sounds tappety. The car has done 182000 and is a 325I, could i tighten them done more and if so by how much? Thinking maybe because of engine wear?
cheers
Elecblondie
Thu Apr 30, 2009 1:27 am
No your clearance needs to be set as per the specs, if you tighten it too much it well seize when hot. If the tappets are correctly adjusted and there's still a tapping sound then it would normally indicate a worn camshaft or rockers, remove the rocker cover and inspect the camshaft. More important than the mileage is how well maintained it is.
richy187
Thu Apr 30, 2009 7:45 pm
You sure its not the injectors making that tapping noise?
Elecblondie
Thu Apr 30, 2009 7:58 pm
Another candidate would be a slight leak on the exhaust manifold. If in doubt use a screwdriver as a stethoscope to find where the noise is.
stonesie
Thu Apr 30, 2009 8:05 pm
The easiest way to check the injectors is simply to rev the engine up, as the revs come back down the injectors turn off until it's down to about 1-1.2K, then they come back on to keep it from stalling.
2nd easiest, get a long screwdriver/pri bar and clean the end of the handle, put it to your ear and touch the other end on the rocker cover and injectors and see which is loudest :wink:
