How do you undo viscous fan coupling, keeps turning
Sun Apr 19, 2009 3:16 pm
i'am trying to undo viscous fan coupling and the spindle thing behind just keeps turning with it, turning the alternator etc.
how do you stop this from turing :cry: :cry:
Sun Apr 19, 2009 3:35 pm
Hit the spanner HARD with a hammer. Reverse thread, don't forget.
monkey
Sun Apr 19, 2009 3:36 pm
if you hit the viscous fan spanner then it should undo remember its left hand thread . too slow typing
Sun Apr 19, 2009 3:41 pm
i relise its reverse thread, but it just keeps turning, the belt also makes a noise when car is running as its a bit loose but it looks like the alternator is "pulled out" as far as it goes to tighten it
i will try the hammer approach
Sun Apr 19, 2009 3:46 pm
no use belt just keeps turning with ease
blingsta
Boost Junkie
Sun Apr 19, 2009 4:10 pm
needs the shock treatment mate, see if you can wedge the pulley in any way just to add the extra bit of resistance and just try and whack it a few times to shock it.. !
good luck mate... dont give up
Sun Apr 19, 2009 4:21 pm
just been and bought some new belts so i will fit them and see if i can tighten it up any more
Sun Apr 19, 2009 5:17 pm
all done ended up just jamming it with a large screw driver
thanks :thumb:
Ritz
Sun Apr 19, 2009 5:21 pm
Alex wrote:all done ended up just jamming it with a large screw driver
thanks :thumb:
Well done, I had a similar problem too!
Sun Apr 19, 2009 6:17 pm
car no longer overheats in traffic, although at the same time i discoved that the radiator is well shagged
it makes a bit of a hissing sound after a run out, and car seems to be using a small amount of water so i assume that its the rad now
going to replace all hoses, thermostat, and rad
