'92 318i m40
i've just checked my crank sensor resistance as suggested on past posts looking for 540 ohms ish. it actually gave me no reading at all, basically infintiy......is this normal for a duff sensor?
cranks sensor
- Brianmoooore
If it's open circuit across all three pins, then it is definitely duff.
It doesn't prove it's a good one, even if you get the correct 540 ohms.
