I was putting new fluid into my 3.64 lsd and when i went to tighten the lower bleed bolt i cracked the part underneath it.
Can this be repaired?
Can it be welded?
i have a spare standard diff and it seems to be the same size.
Will this fit?
any suggestions?
LSD hairline crack
The drain plug on the alloy cover? If so just replace it with the other one you have.
Parts for sale - http://www.e30zone.net/modules.php?name ... 45#2733745
