'89 Sport not reaching normal temperature?
Ritz
Sun Mar 15, 2009 9:24 pm
My G reg '89 Sport has been taken out after 6 months in storage. Everthying brill apart from one minor thing...
Past couple of drives I've noticed the temp needle doesn't go to the middle of the dial (as normal), hangs just before halfway mark.
Any ideas?
Sun Mar 15, 2009 9:25 pm
Mine does the same thing, don't think i have ever seen it go to the middle :?
georgen
Sun Mar 15, 2009 9:27 pm
I've had several 6 cyl E30's now, and the temp guage has always sat at a different position in every one of them !
As long as she's not overheating, I wouldn't worry fella..
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
Ritz
ImysE30 wrote:Mine does the same thing, don't think i have ever seen it go to the middle :?
Really? It was actually noted in the service by a BMW specialist last April 2008 - I didn't notice until I read the service records again couple of days ago.
scottidog
Sun Mar 15, 2009 9:28 pm
Mine was always below half way mark but over the quarter mark. Try a thermostat if its bothering you, easy fix and cheap too.
Sun Mar 15, 2009 9:29 pm
Yep and i've had the car about 2 years. Not really bothered me, only start to worry if he went near the red
Ritz
Sun Mar 15, 2009 9:30 pm
georgen wrote:I've had several 6 cyl E30's now, and the temp guage has always sat at a different position in every one of them !
Yeah its not overheating so not stressing that much. I can hear the fan roar at when you rev it at high temp so thats all ok.
Just thought there might be a faulty temp sensor or something...
Sun Mar 15, 2009 10:31 pm
Mine has always sat just before half way. I have recently replaced both temp sensors and thermostat and its the same.
Dont worry about it.
Sun Mar 15, 2009 10:32 pm
I suppose I'd better type this out once again: The E30 temperature gauge is not linear - it's compressed at each end, with the whole centre section, from just clear of the blue to just before the red, covering just a few degrees. The needle anywhere is this whole section is fine, according to BMW.
In practice, E30's have the needle just past the 1/4 mark, or almost exactly on the centre mark, depending, presumably, on the thermostat fitted.
nickso
Mon Mar 16, 2009 12:31 am
Brianmoooore wrote:I suppose I'd better type this out once again: The E30 temperature gauge is not linear - it's compressed at each end, with the whole centre section, from just clear of the blue to just before the red, covering just a few degrees. The needle anywhere is this whole section is fine, according to BMW.
handy to know.
why haven't we got an FAQ section so brian doesnt have to churn all this top knowledge out time and again?
'88 e30 328i M52 track bint.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Mon Mar 16, 2009 12:52 am
I've created a page for on the wiki for the temperature gauge and also an FAQ page.
The temp gauge page is currently purely Brian's text from above - Brian let me know if that's not ok and I'll change it just enough to be clear of any intellectual property issues :)
Now the FAQ page also exists - please try to update it guys.
http://www.e30zone.net/e30zonewiki/index.php/FAQ
325zimmer
Tue Mar 17, 2009 3:35 pm
Mine did this after I changed my head gasket. I put in new sensors and thermostat and it did the same.
Then i ran an earth from the sensor to the (-) earth post on the strut.
This sorted it and it sits bang on the middle now. :D
