De catting 318is
Hi Guys, does anyone know what i need to do to de-cat my 1990 318 is. Its a euro car so has the cat and ideally I'd like to keep it for test purposes visually at least
The cat is already empty, but makes a noise like a moped LOL Does anyone know If i can weld a pipe into the cat, or do I have to remove it completely and put either a flexi joint/pipe or straight piece of pipe on. I have no idea, so if anyone can help that would be great, thanks chaps
m666w wrote:i think you might get a few more horses alex
you dont need a cat for mot if the car is pre 1992 .
positive, ive checked the vin on that vin decoder thing on the net and it says its fitted with one, it also looks like it has one underneith, there is two boxes one must be the box you are on about and the other must be the catDHFiS wrote:Are you sure it has one? There is a silencer that looks like a catalyst but there is no lambda sensor.Alex wrote:before fitting my stainless steel exhaust i may decat mine, is it acutally worth it ??????
Fair enough. I'd remove it then, the ECU will still work without the input from the lambda.Alex wrote:positive, ive checked the vin on that vin decoder thing on the net and it says its fitted with one, it also looks like it has one underneith, there is two boxes one must be the box you are on about and the other must be the catDHFiS wrote:Are you sure it has one? There is a silencer that looks like a catalyst but there is no lambda sensor.Alex wrote:before fitting my stainless steel exhaust i may decat mine, is it acutally worth it ??????
DHFiS wrote:Fair enough. I'd remove it then, the ECU will still work without the input from the lambda.Alex wrote:positive, ive checked the vin on that vin decoder thing on the net and it says its fitted with one, it also looks like it has one underneith, there is two boxes one must be the box you are on about and the other must be the catDHFiS wrote: Are you sure it has one? There is a silencer that looks like a catalyst but there is no lambda sensor.
Must have been an option...
The spec sheet for my 318iS I got from Cotswold BMW shows that it was bought without a CAT. It has one now though. If a car that old doesn't require one by law why would it have been fitted?
rust never sleeps
i got the spec sheet for mine and its a bum basic IS and never said it had a cat although it doesMrWhite wrote:Must have been an option...
prehaps it could depend on the dealer or whoever was on the production line that day
Check that you've got a lambda sensor. An easy way it to look for a 4pin round connector under the battery tray. If that's got a blanking plug then it's got no lambda sensor, no lambda sensor == no cat. As said above the stock non-cat system has two boxes in the centre leading people to believe they have a cat when they don't.
http://www.bmw-z1.com/VIN/VINdecode-e.cgi
that tells you weather you have a cat via the vin
mine does
Chassis number EE47738
Vehicle code AF92
Series E30
Model 318is
Body type coupe
Catalog model ECE
Production date 1990 / 09
Engine M42
Transmission Manual
Steering Right
Catalyzer YES
mine does
Vehicle code AF92
Series E30
Model 318is
Body type coupe
Catalog model ECE
Engine M42
Transmission Manual
Steering Right
Catalyzer YES
There is now a massive hole under my battery tray where I attacked it with an air saw, don't remember seeing any connector. However, I put my VIN into the site mentioned above and it says it does have a CAT. (?)hoshy wrote:Check that you've got a lambda sensor. An easy way it to look for a 4pin round connector under the battery tray. If that's got a blanking plug then it's got no lambda sensor, no lambda sensor == no cat. As said above the stock non-cat system has two boxes in the centre leading people to believe they have a cat when they don't.
rust never sleeps
Just checked mine and this website says catalyzerYES as well. Defo no lambda on mine though.Alex wrote:http://www.bmw-z1.com/VIN/VINdecode-e.cgi
mine does
Vehicle code AF92
Series E30
Model 318is
Body type coupe
Catalog model ECE
Engine M42
Transmission Manual
Steering Right
Catalyzer YES
