HT leads
- breihill01
I got a set of replacement leads for my 89 325i. Went to change them all and the plugs. on no6 there is a connector around the lead running to a connector near the diagonistic plug.
Has anyone figured out what this does as my new set does not have this.
currently feels like there is 1 cylinder down but I think its a bad lead to plug connection. but cant seem to make it work better until I manage to get leads all sorted.
If anyone has the haynes manual the connection can be seen in picture on page 1.18 pic 15.11a
Any help would be great. I miss my cylinder!
- breihill01
So its only for diagnostics. And I can have my motor running sweet again!
Very fast reply. Was thinking it could be for ignition timing return for the ecu so it knows where it is and will keep it in check.
- breihill01
I initially changed the plugs as was just doing a service. When I put in the new plugs I could not put on the tops of the plugs the part that makes the connection. This then left me with a car that seemed underpower and had a hessitation around 2k revs esp when at 50mph in 5th.
Decided to change leads aswell as I think they are original.
Is the pickup just magnetic and has 2 wires running to the sensor?
- breihill01
I did this but this left me with the cylinder problems. have tried other plugs as i 1st though that 1 was faulty. just dont seem to be making the right condition when cap is off. just that the problem arose after i changed the plugs.
- Brianmoooore
You do realise that some plugs need the outer part of the connector unscrewed and discarded?
The inductive pick up on the plug lead is the M20's equivalent of a cam position sensor. Like most engines, it will run without its input to the ECU, but will run better with it.
It was used for diagnostic purposes only on very early management systems.
- breihill01
ok back to the magnetic pick up. this should just be a pulse sensor that works by the induction from the spark plug lead.
this is a continuous band of metal in a plastic case. is this a certain type of metal or is it magnetised?
any help always useful
- breihill01
that does explain the running its just not right at cruising speed and would explain some of the carbon on the plugs.
need to try to get my sensor back on but not shelling out £75 for new ht leads! was thinking cut the sensor and resolder in on the lead. I no heat on ht wont go well
- breihill01
I can be around that end of the country but it might be a few weeks. normally involves a run to the airport. any excuse to get the 325 out on the road!
will keep you in mind esp cause id love a look at an m50 in an e30 in person.
- breihill01
thats not right. if they had any sense they wouldnt touch a mans pride and joy.
i think double barrel is the only job for scum like that.
if im down ill def give you a shout.
