can anyone guide me in the right direction?
my m40 has a hard time ticking over when cold, and sometimes cuts out when pulling up to traffic lights.
i'm straining the alternater a bit with two batteries(1 on switchable charge), which pulls the revs down a touch.
but the rough cold start, and lumpy running after a short rest period is getting on my nerves now...
so if anyone can help with some info, it would be appreciated.
dan.
						m40 problems.
				StefanAnghel
 - Contact:
not 100% sure but lumpy running might be because of ICV - remove it and give it a good clean with carburator cleaner
I'm sure that a full list of things to be checked will be posted in...seconds
idle,control valve...or the pipe that  goes to the air flow meter,,could be perished/split..
i have a few i,c,v's off m40'si'll post you two for £15 if needed...this will sort it out..
+ a yard full of scrap turds
				streetbassincuk
i'll give it a blast with some carb cleaner.
any ideas on the cold start problem??
thats what it is.it sorts ya revs out when cold till warm.icv.
they do fail and cost about £100 from bmw
				streetbassincuk
ok, my bad...is it not worth getting a new one? least it'l last a while...
is it causing the cutting out when i slow down as well?
					Last edited by streetbassincuk on Tue Dec 23, 2008 1:22 am, edited 1 time in total.
						up to you m8,,i have 5 of thesestreetbassincuk wrote:ok, my bad...is it not worth getting a new one? least it'l last a while...
