Remove or cover fuel tank during welding/sawing
skipunda
Sat Dec 20, 2008 9:30 pm
Hi all,
bit of professional advice please :)
I'm usually very safety conscious and under normal conditions I'd take the petrol tank out when doing any work where sparks or sharp tools are involved. I really don't fancy removing the petrol tank for this car - it's not like the biscuit tin I did in an old Micra - plus i've just learnt I haven't got access to a pit next month to remove it anyway
Would v.wet rags, spray flame retardant spray etc. be enough for sparks?
will be...
Removing either all or at least major sections to sill, both sides.
Removing and refitting both outer wheelhouse inner arches plus two outer arches
Grind/saw/cut lower rear quarters
fuzzy
He who sleeps with "Gingers"
Sat Dec 20, 2008 9:45 pm
depends on the condition of the tank, i welded strengthening plates on my rear axle in position with some damp towels on the tank but my tank is a year old and in perfect condition and no petrol smells.
skipunda
Sat Dec 20, 2008 9:49 pm
no petrol smell, fuel lines in perfect condition. Good condition but probably the original.
Anything I should look out for with the filler 'neck' where it joins tank? Is there a seal that could perish?
Dave_M3
Sun Dec 21, 2008 4:10 am
There's no seal other than a wicked tight fitting hose pipe at the filler neck.
**BANNED**
Sun Dec 21, 2008 11:47 am
Frankly if you are cutting so much out of the shell,an extra two or three hours to remove the tank and make yourself safe seems a small price to pay.As you mention,there is a rubber joining pipe between the filler and the tank,and some of your work is going to be close to this.The weak point of the tank is where the filler pipe enters it, the welded joint here fails....
Youth is wasted on the young.
patch
Sun Dec 21, 2008 12:44 pm
Trouble is if something catches fire you can put it out
but if the tank goes you loose the building !!!! :eek:
Coffin dodger still driving a
Crusher dodger
skipunda
Sun Dec 21, 2008 6:06 pm
daimlerman wrote:...there is a rubber joining pipe between the filler and the tank,and some of your work is going to be close to this
Yep, question answered. It's the vibrating of the chassis etc while grinding away...maybe this join will be a bit weak - I can see someones already given it a clout with a hammer.
i'll remove it one way or another. cheers :thumb:
fuzzy
Mon Dec 22, 2008 10:04 am
just keep a fire extinguisher handy.
