oily spark plugs
any ideas why 3 out of 6 of my plugs would be covered in oil, it was miss firing, cleaned em up and it all fine now. have to wait and see if it happens again. would it be the valves are not seated properly or does it sould like a crack somewhere
Black_Potato
- Contact:
Valve stem oil seals... maybe..
do you mean the outside of the plugs were covered in crap or when you took the plugs out the end of the plug (electrode) was covered in oil?
The ends of the plugs where the electrodes are. It can't be a piston ring could it. It not letting out much smoke out the exhaust which prob rules that out. Strange, could it have anything to do with a valve
hmm now that I think of it valve stem seals have not been changed on this head, if they are knackered would oil drip into the combustion chamber, but surly that would affect compression, or would it just get burnt and straight out the exhause manifold.
Morat
Valve stem seals show blue smoke on startup from oil burning off which oozed in overnight. As they get worse, you get more oil coming in - up to the point when you get blue smoke pretty much all the time. Penny parts, but it is a head rebuild to replace them. You'll eventually fail your MOT on emissions so get in there well before it is due or start building up a replacement head you can swap nearer the time.
