****URGENT PLEASE HELP***
Locked
beem
Sat Nov 29, 2008 6:48 pm
Ive locked my one and only Key in my boot,doors are open but cant get access through the back seats,for some reason the central locking isnt opening the boot.
Please any ideas???
Cloud
Mmmmmm Donuts!
Sat Nov 29, 2008 7:06 pm
Isn't the central locking on a relay? Maybe you could take the relay out and put 12v into the terminals, to get the locks to open. Or screwdriver the lock itself.
monkey
Sat Nov 29, 2008 7:10 pm
can't you sit in the car with the doors shut and lock and unlock the doors a couple of times via the door pin on the inside of the door , maybe that will get the boot lock motor working
Sat Nov 29, 2008 7:20 pm
not that easy, depends on wether the boot was turned and locked seperately from the rest of the car.
What position is the key slot on the boot lock, vertical or horizontal?????
If horizontal, then no luck mate as it will be locked seperate fron the c/locking ( this was so you can lock things away safely)
If vertical, should open with the c/l
hth :cool:
Sat Nov 29, 2008 7:22 pm
take out the rear seats m8 you'll see an oval panel in the middle what's only tack welded on.
boot it in or pry the welds with a big flat screw driver,,,get it off any way,,,if you have a nipper send in a kid
but carefully,,,or get a coat hanger and retrieve keys..this panel will come off easy it's for ski's??
leeparkes
Sat Nov 29, 2008 7:23 pm
if youve got to 'break' in either go in through the rear light or ski hatch panel
Sat Nov 29, 2008 7:24 pm
i suppose thats the subtle approach :mad: :mad: :mad:
beem
Sat Nov 29, 2008 7:28 pm
Fair play lads i got in through the ski hatch!!! 2 belts of a hammer and the panel fell through!! cars locked up and safe for the night now. Too cold to put everything back together tonight though. Cheers again lads.
Sat Nov 29, 2008 7:32 pm
yes result,,,i helped someone :D nice mk11 in avatar m8 8)
Locked
