As per title, i've got a strange problem with my indicators...
It will indicate left fine, but when i try indicating right, then it ticks quikly like a bulb is out.
If i put the hazard lights on, then all lights work.
I have noticed that when i'm indicating right that the green arrow on the dash doesn't light up at all.
I've checked the fuses, and it doesn't look like any of them are out.
Strange indicator problem
Mine had exactly the same symtoms and the strange thing is it was a slightly loose battery terminal that caused it. Tightened it and never had the problem again(still have the bulbs I got from Halfords incase the bulbs were shot)
I've just changed the hazard switch with a working spare and it does the same thing...the terminals on the plug that the hazard switch go into are perfectly clean...
Will have a look at the battery tomorrow now...can't see anything outside right now.
any more suggestions??
Breaking 325i Touring
- oi_oi_savaloy
I had this exact same problem on mine a month ago. Exactly the symptoms you described.
So I bought a new indicator stalk off Spadge on the forum for a tenner posted and replaced it. Problem solved.
£6 - £10 is about right for a 2nd hand indicator stalk.
Hope that helps.
Hope that helps.
I think i have an indicator stalk somewhere. do they just unplug?
I'll have to cut the end off as i have a motorised screen head-unit and require clearance for that.
- Brianmoooore
Get yourself a LH drive radio/clock/switch panel.aceraf wrote:I think i have an indicator stalk somewhere. do they just unplug?
Indicator switch is held on by two screws that you can see when you take the steering wheel and lower shroud off, and the wiring has a plug/socket about six inches along the wire.
