What Diff would be best?
Daz318is
Fri Nov 07, 2008 1:34 pm
Hi
I've got a standard 318is and use it for work, thing is it seems to rev a bit high in 5th, like it could do with a 6th gear, anybody any idea what Diff i could swap it to, to lower the revs?, dont need fast acelaration just relaxed cruising
Darren
leeparkes
Fri Nov 07, 2008 2:28 pm
3.64
andrews
Fri Nov 07, 2008 2:36 pm
According to specs 4.10 ratio diff is installed on your car(if stock condition). So if you want to lower the revs you should try a diff with lower ratio value(3.91 or 3.64 as leeparkes offered for instance)
Dear englishmen, if I make a mistake, correct me please ))
**BANNED**
Fri Nov 07, 2008 2:39 pm
You should have a 4.1,about 65mph at 3000rpm. A 3.64,as suggested above will be about 75mph at 3000rpm. Diff ratios are marked on a tag attached to one of the rear cover bolts,BTW. Two sizes of diff were fitted to E30's,small one has 6 bolts to the rear cover,other has 8 bolts. They are interchangable with a small ajustment to the length of the propshaft.
Youth is wasted on the young.
Daz318is
Fri Nov 07, 2008 3:57 pm
Thank you all!!!!!!!!!!!!!!!!!!!!
:D :D will roll under the car to check whats under there, :cry: and see if i can find a 3.64
Darren
Fri Nov 07, 2008 8:45 pm
a 3.64 would make an iS VERY sluggish with accelerating.
If it was me i'd go 3.91
Got to remember you've got a revvy 16V engine there.
The wife's 16V golf is doiung 5k at 100mph :eek:
StuBeeDoo
Fri Nov 07, 2008 8:49 pm
E30BeemerLad wrote:a 3.64 would make an iS VERY sluggish with accelerating.
Got to disagree Lee. I've had a 3.64 in my 320i for 3 years now. I've been happy with the performance, and I doubt if more than a handful of really good drivers could notice a difference in it.
iS has slightly more power than the 320i, so results should be similar.
Jon_Bmw
Dangerous when thinking
Fri Nov 07, 2008 8:58 pm
That sounds familar Lee. A proper 100mph with a gearing calculater works out at 5236rpm :)
On the plus side full throttle changes from 2nd to 3rd see the revs drop to a mear 5136rpm, 3rd-4th 5586rpm 4th-5th 5773rpm.
Always in the mi16's sweet spot. :D A poor 12v unit would be dead in the water at those rpms :o
Agreed about the 3,64 that would be seriously lame.
Fri Nov 07, 2008 10:52 pm
Ah but does the 320 have the same closer first couple of ratios like a sport box, compared to the 240 box in the iS homodominatrix?
Sat Nov 08, 2008 12:11 am
A 320 uses a 240 box, the same as the 316 and 318.
Sat Nov 08, 2008 12:27 am
now where did I put that spade
StuBeeDoo
Sat Nov 08, 2008 7:41 am
E30BeemerLad wrote:Ah but does the 320 have the same closer first couple of ratios like a sport box, compared to the 240 box in the iS homodominatrix?
Nope! All ratios identical. :D
Daz318is
Fri Nov 28, 2008 12:33 pm
Thanks for all the help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :mad: :x :eek: winkeye :wink:
darren
dannyboy759
Fri Nov 28, 2008 3:26 pm
If it was me i'd go 3.91 :D
