5 Series 5 stud onto E30?
Project_E30
I have a 5 series that I am about to break G-Plate (E34). Just wondering if I can use it to convert my E30 to 5 stud?
paddy2bsure
You would need the M3 set-up to convert - expect to pay Ԛ£650 too! That buys a lot of wheels!!!
Best off binning your old 5-series stuff on Flea-Bay!
Project_E30
Is a 5 series swap not possible then people?
A1BMW325iSport
- Contact:
totally different, if you want 5 stud, M3 kit is the only way.
Project_E30
Thanks answering but what makes it impossible? Out of interest
Nothing is impossible, but lots of things are pointless and aggro, if you want 5 stud wheels on your e30 the only viable option is to fit e30 M3 components, they fit straight on and work. Heroes with too much time on their hands will talk about e36 compact rear flanges etc etc, but they have to be bought also. I have a complete bolt on 'kit ', the bigger M3 brakes will connect up to your stock fixed lines and work , the M3 antirollbars will bolt up to the standard e30 mounts and the abs sensors will plug in and work, all this for Ԛ£650!!. If you value your time it can not be done cheaper!.
