what fuse
mattyray
Wed Oct 22, 2008 11:09 pm
what fuse can be removed so the car wont start just need to make my car a non runner temperelaly thanks
ucpsale
Wed Oct 22, 2008 11:12 pm
You could always remove the HT coil lead.
wildeian
Wed Oct 22, 2008 11:13 pm
11 fuel pump
mattyray
Wed Oct 22, 2008 11:14 pm
cheers fellas
leeparkes
Thu Oct 23, 2008 3:42 pm
put a blown fuse back in so everything looks normal,(fuse 11)
or pull the rear seat up,undo 4 screws lift the inspection plate and disconect the fuel pump(take you 10 minutes)
jbh
Hartge Crew
Thu Oct 23, 2008 3:55 pm
you could also pull out the bridge on the loom where the standard imobiliser would plug in if you take the cover off in the glove box you will see a plug with 2 green wires going to it there should be a plug with a loop on it that plugs in there with this removed the car wont start.. you could also wire a switch onto that if you wanted and hide it somwhere
mattyray
Thu Oct 23, 2008 7:01 pm
thanks for the imput all think im gonna go 4 fuse 11 and put a blown one in to hide it cheers
