Tool Steering WHeel
Thu Oct 02, 2008 9:23 pm
What tool do I need to take off the steering wheel?
eko
Old timer
Thu Oct 02, 2008 9:24 pm
22mm socket :wink:
Joe-318i
Thu Oct 02, 2008 9:25 pm
did mine the other week :D
im sure it was a 22mm deep socket
StuBeeDoo
Small screwdriver to get the horn-push off and 22mm socket for the hub nut.
frogman
Thu Oct 02, 2008 9:27 pm
Make sure you torque it when refitting wheel. (I think its 82 Nm I'll have to double check the workshop manual). They say to replace the lock nut. I reused mine with thread locking compound.
Thu Oct 02, 2008 9:42 pm
And does anyone know where I can get the ratchet with a full set of sockets?
patch
Thu Oct 02, 2008 9:44 pm
put a mark on the wheel and the spline so you can put it back in the right position,as you need to release the steering lock :)
you can get the tools in halfords(lifetime guarantee)
Coffin dodger still driving a
Crusher dodger
Thu Oct 02, 2008 9:54 pm
patch wrote:put a mark on the wheel and the spline so you can put it back in the right position,as you need to release the steering lock :)
Like this one? (I'm a noob)
http://direct.tesco.com/q/R.204-9606.aspx
Thu Oct 02, 2008 10:01 pm
I doubt very much if a 1/4" drive set goes up to 22mm.
Thu Oct 02, 2008 10:11 pm
I just need a Socket set which can cater for everything on the E30.
BadDave
Thu Oct 02, 2008 10:12 pm
Brianmoooore wrote:I doubt very much if a 1/4" drive set goes up to 22mm.
Not much chance of a 3/8" set going that high either
Best with a 1/2" set TBH
BadDave
Thu Oct 02, 2008 10:14 pm
Blitz wrote:I just need a Socket set which can cater for everything on the E30.
Ideally a set with both 1/4" and 3/8" in one and a 1/2" set would suffice
Ziggy
Thu Oct 02, 2008 10:15 pm
You'll definitely want 1/2" for some things, & I doubt there are many socket sets out there that include everything - hub nuts, crank nut etc.
The halfords professional sets are good though, & they do some pretty comprehensive ones! Rather more expensive than that Tesco set though.
Thu Oct 02, 2008 10:20 pm
How about if I go for these now, and would any ratchet fit?
http://cgi.ebay.co.uk/9-PCE-HEAVY-DUTY- ... 286.c0.m14
Thu Oct 02, 2008 11:11 pm
this will do you nicely for a 1/2" drive set 8mm-32mm sockets
http://www.machinemart.co.uk/shop/produ ... -tool-sets
1/2" deep socket set
1/4" drive set with ratchet
Thu Oct 02, 2008 11:14 pm
by the way, a useful tip when removing the wheel. take the nut off, but then thread it back on a couple of turns so it sits at the end of the thread on the column, then when you give it a big hoik on the wheel to pull it off the spline, you won't smash yourself in the face with the steering wheel when it suddenly comes free. :wink:
Thu Oct 02, 2008 11:18 pm
if you dont have many tools something like this will be a good start
http://www.argos.co.uk/webapp/wcs/store ... c+Tool+Set
im sure there will be a 22mm in there
they wont be the best quality but will do the job :thumb:
Chris
Thu Oct 02, 2008 11:23 pm
Seconded, just bought one of these sets and its pretty good for the price.
Not the tightest ratchet in the world but does the job quite neatly and comfortably.
Fri Oct 03, 2008 6:53 am
Or Halfords professional. I've found that a lot of the "full" sets include stuff you never use. I would go to Halfords and buy a strip of 1/2 inch drive professional sockets, a 1/2 inch drive ratchet and short and long extentions. Then do the same with their 1/4 inch drive set. They are gaurantteed for life as well.
Fri Oct 03, 2008 8:21 am
whipsey
Fri Oct 03, 2008 8:57 am
E30BeemerLad wrote:by the way, a useful tip when removing the wheel. take the nut off, but then thread it back on a couple of turns so it sits at the end of the thread on the column, then when you give it a big hoik on the wheel to pull it off the spline, you won't smash yourself in the face with the steering wheel when it suddenly comes free. :wink:
shame you can't do the same with the gearknob that one hurts winkeye
