Are all air-con compressors the same?
Nick_TBMW
Fri Sep 12, 2008 12:43 pm
I'm currently struggling to find an A/C compressor for a 318iS/M42 engine, but I've managed to find one for an M20, but, after checking on www.realoem.com, it seems that the part numbers are different.
I know the compressor mounting bracket is engine-specific, but is the compressor also engine specific?
Any help would be much appreciated.
Thanks,
Nick
sam325is
Fri Sep 12, 2008 2:47 pm
not sure about engine specific but make sure its made by seiko seiki and not bosch if you intent to use r134a
town325i
Fri Sep 12, 2008 2:51 pm
it the part numbers are diffirent that most likley means they are different
Nick_TBMW
Fri Sep 12, 2008 3:38 pm
Thanks guys. If anyone could confim, it could possibly save me about £600 winkeye
gazza
Fri Sep 12, 2008 8:53 pm
i have just fitted a sieko sekkei one from a m40 to a m20 only the mount was different but the m20 has a angled pipe on the top to keep the pipe away from the m20 manifold (the pipe is interchangeable between applications)
the compressor i have is the later e30 type and was fitted to both m20 and m40 ....a point to add is the pipes are different where they connect to the compressor as the m20 engine is longer and thus needs longer pipes but only the pipes that connect to the compressor differ all the rest is the same
