rattle driving me mad. Changed top mounts. Didn't fix it
ChrisBarns
- ConvertibleChris
I have a "tinckle" from somewhere around the rear suspension, drivers side. I've changed the knackered top mounts and wiggled every thing in the area but can't find anything loose. It sounds a bit like a heat sheild is loose or a wheelnut has come off and is bouncing around inside the centre cap.
Help please!
325i convertable
Help please!
325i convertable
- **BANNED**
Is the bump stop correctly positioned on the damper?Is the damper lower mounting bolt tight
Youth is wasted on the young.
ChrisBarns
- ConvertibleChris
lower mounting defo tight - just tourqued it up. Where is bump stop?
ChrisBarns
- ConvertibleChris
defo comes from underneath the car and happens when I go over bumps. Was there beofre I replaced the top mounts.
- **BANNED**
The bumpstop is on top of the damper and under the plastic shroud,only mention it because when I recently fitted new dampers/top mounts I managed to assemble I with the bumpstop on top of the shroud and that side knocked...the other side knocked because I failed to tighten the lower bolt....
Is the noise like a jingle when you go over bumps ? If so, I reckon the brake guard retaining pin thing is loose. I have the same noise on mine, but I'm about to change the guard and pin ( which I know is loose ) when I get the rear wheel bearing done next week.
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
- murran
yeah mine rattle too. no big deal really.mattsbmw wrote:Barke pads rattleing? mine do but most of the time, not just going over bumps
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
- Brianmoooore
Rear silencer heat shield!
