325i air leak
garyn
Sat Jul 12, 2008 6:51 pm
Hi , on my mission to get this thing to start a bit easier ive noticed that when it does finally go , and i if i remove the oil filler cap the engine nearly stalls and runs like a bag of spanners ,ive read somewhere this suggests an air leak as its creating a vaccum , if this is the case where do i start to look for it , ive tried to hit it with wd40 ,but no difference when doing it ,any ideas ????
Sat Jul 12, 2008 9:39 pm
You're getting things a little confused! Run like a bag of spanners, and nearly stall, is what it should do if you remove the oil filler cap.
The crankcase normally operates under a partial vacuum, and if you remove the filler cap, air is sucked in and through the breather pipe into the inlet manifold, where it weakens the mixture.
garyn
Sat Jul 12, 2008 9:40 pm
dont we do air leaks ??
garyn
Sat Jul 12, 2008 9:42 pm
thanks for that brian ,but would it not take a fairly serious air leak to cause problems starting from cold ,ive changed all the usual suspects ?
