carpet out anything i could do while its out?
scurran83
Wed Jul 02, 2008 10:34 am
Just took out my carpet to steam clean it. Found a small rust hole so getting that welded but is there anything else you would recommend i do while the carpet is out?
Cheers. :D
Wed Jul 02, 2008 1:41 pm
Hunt very carefully for more holes! The slightest pitting or discoloration in the panels is likely to be a rust hole.
If you see any suspects, then prod at them hard with a small screwdriver. These holes rarely improve with time, and this is a good opportunity to sort them.
scurran83
Wed Jul 02, 2008 2:37 pm
will do brian, just hope the screw driver stays more inside the car than out. thanks
DCDC
Wed Jul 02, 2008 5:13 pm
get a new carpert - dont cost much for the lot from a scrapy. :mad:
scurran83
Wed Jul 02, 2008 9:48 pm
have a new carpet!!! Wet vacuumed the old one and it came up like a brand new one. winkeye
Wed Jul 02, 2008 10:14 pm
scurran83 wrote:have a new carpet!!! Wet vacuumed the old one and it came up like a brand new one. winkeye
As long as the driver's side has been used with a mat, they usually do, however much they've been abused in the past.
scurran83
Thu Jul 03, 2008 10:23 am
yeah brian looks like it has always had a mat in it. What would you suggest for cleaning the rubber heel plate section?
