engine oil question?
- murran
10w40 is fine, make sure its a semi synthetic (most are nower days).
as for how much to put in..... i presume yours has a dipstick too??? minimum to maximum is around 3/4-2/3 of a litre....
the oil light? was it the level light or the pressure light?
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
Mobil 1 too thin?
Thinness is not really anything to do with oil leaking?
If you look at the data below from mobil's and castrol's website, you'll notice that the viscosity at 40 degree C is 80 centistrokes i.e. thickish. then when the oil heats up and thins to 14 centistrokes at operating temperature. You'll notice that castrol edge is slightly thinner than mobil 1 at operating temp. You'll also perhaps notice that mobil 1's mineral S 10W-40 and 15W-40 also thins down to 14.4 centistrokes at operating temp.
So with that in mind, why would mineral 10W-40 stay in the motor better...if it always stays at 40 degrees then i guess yes a visosity argument...but it does not so we need an alternative theory.
Viscosity is also only loosely associated with lubricity, take a fully synthetic 10W40 vs a 10W40 mineral and the fully syn would be slipperier for longer, the base oil is more thermally stable in synthetic oil. And it is this improved lubricity that improves the mpg by switching to say 0W-40 FS. Nearly all the new VAG group cars use FS 0/5W-30 this improves the mpgs and gets their cars under the g/km of CO2.
The leaking that sometimes occurs is more due to the cleaning of the gaskets of vanishes gung etc. out exposing the holes in the gaskets.
Typical Properties
Mobil 1 0W-40
Value
Viscosity, ASTM D 445
cSt @ 40º C 78.3
cSt @ 100º C 14
Sulfated Ash, wt%, ASTM D 874 1.2
Phosphorous 0.1
Flash Point, ºC, ASTM D 92 230
Density @15º C kg/l, ASTM D 4052 0.85
Total Base Number (TBN) 11.3
MRV at -40ºC 26242
Viscosity Index 186
HTHS Viscosity, mPa”¢s @ 150ºC, ASTM D 4683 3.7
Typical Properties (mineral)
Mobil Super M
SAE Grade 10W-40 15W-40
cSt @ 40ºC 98 107
cSt @ 100ºC 14.4 14.4
Viscosity Index, ASTM D 2270 157 141
Sulphated Ash, wt%, ASTM D 874 0.91 0.91
HTHS Viscosity, mPa.s @ 150°C, ASTM D4683 3.95 4.00
Pour Point, ºC, ASTM D 97 -30 -24
Flash Point, ºC, ASTM D 92 230 230
Density @15ºC, kg/l, ASTM D 4052 0.870 0.885
Typical Properties
Mobil 1 Turbo Diesel 0W-40
Value
cSt @ 40º C 78.3
cSt @ 100º C 14
Phosphorous 0.1
MRV at -40ºC 26242
Viscosity Index 186
Castrol Edge Sport 0W-40
Flash point Closed cup: 244°C (471.2°F) [Pensky-Martens.]
Colour Amber.
Physical state Liquid.
Odour Oily.
General information
Appearance
Important health, safety and environmental information
Pour point -60 °C
Density 838 kg/m3 (0.838 g/cm3) at 15°C
Solubility insoluble in water.
Partition coefficient >3
(LogKow)
Viscosity Kinematic: 75.7 mm2/s (75.7 cSt) at 40°C
Kinematic: 12.8 mm2/s (12.8 cSt) at 100°C
Typical Properties
Mobil 1 0W-40
Value
cSt @ 40º C 78.3
cSt @ 100º C 14
Phosphorous 0.1
MRV at -40ºC 26242
Viscosity Index 186
Mobil Super M
cSt @ 40ºC 98 107
Typical Properties
Value
cSt @ 40º C 78.3
cSt @ 100º C 14
Phosphorous 0.1
MRV at -40ºC 26242
Viscosity Index 186
Colour Amber.
Odour Oily.
General information
Appearance
Pour point -60 °C
(LogKow)
