Rear droplinks
Fraz06
Sat Apr 26, 2008 4:48 pm
Hey guys, Im going to be replacing the rear anti roll bar droplinks shortly and im just looking for some advice, has anyone got any tips on how to manovere the rubber part of the droplink onto the anti roll bar? as it looks like a very tight fit.
Thanks Guys
Fraser
hennabm
Sat Apr 26, 2008 6:11 pm
I used washing up liquid and brute force to push mine back on. :mad: I used standard links. The old ones came off not too bad but nothing else would let the new ones slip on far enough other than washing up liquid.
ATB doing the job. :D
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
old_skool
Sat Apr 26, 2008 6:15 pm
Just spit on it and give it a good hard push :)
ian332isport
Sat Apr 26, 2008 7:33 pm
old_skool wrote:Just spit on it and give it a good hard push :)
I bet you say that to all the girls winkeye
**BANNED**
Sat Apr 26, 2008 7:41 pm
If the ends of the ARB have surface rust,give them a clean up first,it always slides better when it's shiny..as the actress said to the bishop...
Youth is wasted on the young.
austin360
get a tight fitting drill bit and spin it in reverse this will heat the rubber maken it soft iss a bit of copper greese ind it should slip on sounds like a bodge but works
