stains on me roof lining
bazcoupe
Tue Apr 15, 2008 11:45 am
ive just noticed lots of water marks on my roof lining (93 touring) would this just be the sunroof drains blocked or a seal on the sunroof
any help apreciated :D
ed325i
Tue Apr 15, 2008 12:14 pm
or could be that the sunroof tray is rotton.
bazcoupe
Tue Apr 15, 2008 12:33 pm
how would i know if it is would it be obvious as i look at it or will i have to drop my lining first.
ed325i
Tue Apr 15, 2008 3:50 pm
Where are the water marks ?
bazcoupe
Tue Apr 15, 2008 4:07 pm
on the edges either side of the sunroof
ed325i
Tue Apr 15, 2008 7:54 pm
I would say the drains are blocked.
Tue Apr 15, 2008 9:37 pm
Sunroof seal is not intended to be a water seal, although it obviously reduces the amount of water coming in.
You can inspect the front of the sunroof area just by opening the roof.
Bewdley320T
Wed Apr 16, 2008 2:48 am
Don't want to worry you but these marks aren't light brown are they? On a lighter note, it's puncture holes from stilletto heels I've got a problem with.
bazcoupe
Wed Apr 16, 2008 8:01 am
yeah they are light brown :?
that bad then :?:
old_skool
Wed Apr 16, 2008 9:06 am
Water marks on fabric are usually all light brown so don't panic. Do as is said and inspect the area thoughly and check the drains. If you are still suspicious then remove the lining and inspect further. I have had success with removing these marks using Autoglym foaming uppholstery cleaner and a damp micrfibre cloth.
**BANNED**
Wed Apr 16, 2008 12:49 pm
Bewdley320T wrote:Don't want to worry you but these marks aren't light brown are they? On a lighter note, it's puncture holes from stilletto heels I've got a problem with.
Pull 'er boots off with 'er knickers...
