Door lock
				shedrool83
				Car-Nut
I had this recently ordered a new lock barrel kit £15.00 from the parts man on here and rebuilt the barrel sorted
									Clive
Things are changing in the stable....
'88 Zinnobar Red E30 325i (Sold and missing it :O( )
http://www.carandclassic.co.uk/car/C50851
'02 Inidividual E39 M5(SOLD)
				shedrool83
- Brianmoooore
The steel forks from the door catch that fit around the L shaped piece alloy piece on the back of the key barrel.
Door lock barrel needs to be taken out and serviced first though.
				shedrool83
Hi there. I've just rebuilt my door lock barrel with the service kit, remounted it, but am still getting a problem where the door doesn't want to lock. What exactly do I need to adjust to get it to pull the button down sufficiently to lock?
				shedrool83
- Brianmoooore
It's a matter of getting in there and studying how it all works. Once you understand it, the problem, and cure should be obvious. (Or at least my posts on the subject should make more sense!)
						Hi Brian. Haven't got this licked yet, as I actually need to pump the key to get the button to go down enough for a 'full lock'! Any tips? At all? Cheers...
Also trying to fix the electrical side of the c/locking. Followed the tech guide on this site, and I'm not getting any clicking relays when I turn the key. Have just done red/black wire mod, and situation is still the same. Is the best course now really to spend £70 on a new relay box? I did examine it, and couldn't find anything immediately wrong.
- Brianmoooore
When the central locking is fully working, as soon as the drivers door lock starts to move the latch mechanism, it activates the locking motor, and this takes over and finishes the movement.
Without the central locking, the driver's door should still lock on the key, but will feel relatively heavy all the way.
Have you opened up the locking module? Press the two relays inside it momentarily, one at a time. One should lock the doors, the other, unlock them.
Hi Brian. The locking motor is obviously not working. The key does lock and unlock the door, but none of the others and does feel heavy. I have opened the locking module (box behind the speaker panel right?) but neither relay is doing anything...
						- Brianmoooore
Connect a 12volt lamp (NOT a meter) between the red/black wire and the brown wire at the locking ECU's socket.
Does it light?
						Does it light?
- Brianmoooore
Try the light between the red/black wire and a good body earth (ECU bracket), just to confirm that the problem isn't with the earth wire. I suspect the results will be the same.
If so, your problem (or at least an important part of it) lies with the power feed to the locking.
First of all check fuse 27, then, if it's easily accessible, connect the lamp between the joint you made when you modified the red/black wires and earth.
- Brianmoooore
Remove the panel above the glovebox (two quarter turn buttons and a self tapping screw), and check for power at the accessories socket at the back, on the pin directly below the four pin radio plug.
Are you sure you've done the red/black wire modification correctly?
Red and black wire mod as I understand it - take rubber boot off connector in door close, take connector out, find two red and black wires, cut em and solder them together.... Oh and the lamp definitely works btw ;)
Yes, power at point you said above, lamp lights.
- Brianmoooore
I think we may have found the problem! The two red black wires that you cut and join are the ones behind the socket for the door plug - the bit that stays in the hinge pillar when you pull the plug out. When joined, you should be able to pull the join out of the hole where the speaker fits.Chris_ wrote:Red and black wire mod as I understand it - take rubber boot off connector in door close, take connector out, find two red and black wires, cut em and solder them together....
Arf. A mo. There's power at the drivers door now, can hear it, but the passenger door still doesn't want to lock! Another thrilling installment soon I'm sure. Thanks for your guidance Brian, look forward to the next thing I've got to try
						- Brianmoooore
Check the passenger door plug and socket for corrosion.
It's important that the rubber boot is fitted back onto the plug properly before the plug is pushed back into the socket. This applies to the driver's side as well, which you have recently had apart.
A good helping of silicon grease on the pins doesn't go amiss, either.
- insertnamehere
If you've actually seperated the driver's door plug, rather than just doing the red/black wire chop behind the speaker then I'd bet real money (not that photocopied stuff I try to use at the shops!) that you'll be into replacing all the pins in that now they've been disturbed & no doubt disintegrated.
Saying that, you could just give the plug a spray & a wiggle where it goes into the pillar & hope for the best...
1977 Austin Allegro 1300
1992 FIAT Tipo 1600 (SOLD!!!
1977 MZ TS250/1 "supa-5"
1993 Cagiva Mito 125
1987 E30 318i (Daily driver for????)
1988 E30 325i (Not anymore, let down by seller...)
- Brianmoooore
Very possibly a poor connection in the door loom plug and socket, since you've had this apart. Otherwise, if the passenger window works, it's probably the switch.Chris_ wrote:FAILURE! Drivers side electric window's stopped working on the way home from work. What have I done then?
Swap the switches over as a test.
Thanks guys, sorry for the delay in replying, been away. Since coming back however, the window's started working again.. Think it's just tempremental, it's failed to work for about 30 secs once before. No doubt it'll break again once I've reattached the door card
Next job is fit the stereo, more electrics, hurrah!
				shedrool83
Having a go at this today and i'm getting power to the pin below the 4 pin plug.Brianmoooore wrote:Remove the panel above the glovebox (two quarter turn buttons and a self tapping screw), and check for power at the accessories socket at the back, on the pin directly below the four pin radio plug.
But there is nothing connected to it.(is this right or should there be a plug connector in there?
Is this the reason i have no power at the red and black wire behind the drivers speaker?
				shedrool83
Right i'm getting somewhere now i think.
If i take a live to the red and black wires that are joined for the central locking modification the central locking opens and locks the doors from the passenger door.
So i'm guessing there should be a plug somewhere to connect to the pin behind the glovebox but i can't see it anywhere.
Would it be ok to take a live from somewhere else and join it at the red and black in the drivers speaker well?
This is doing my nut and i still have to fix the drivers door lock
- Brianmoooore
The socket at the accessories connector is for the OBC alarm function and nothing to do with the locking as such, but power here proves that the relevant fuse and its holder are OK, and the red/black wire down to as far as a soldered joint behind the glovebox, where the wire to the accessories socket tees off.
The red/black wire goes from this soldered joint all the way back the LH sill, across the rear seat, and all the way over the RH sill to the door pillar socket - one of the one's you should have cut off.
If all you say is correct, then this wire must be broken, but this is unlikely, as its part of a loom.
Are you sure you've done the red/black wire modification properly, with the correct wires? You must have got one of them correct though, for the locking to work when you apply power to the join.
				shedrool83
Brian i've had it all working at one point.
I've done the red /black mod as of smithy318i's guide.I changed the motor in the drivers door and took power from the
6 button gong and it was working fine when operating the drivers door button(still have problem with door lock).
I've just put the door card back and tried it again,now the 6 button and the central locking isn't working and the passenger and back doors are dead locked.
				shedrool83
				shedrool83
