Brake lights
Aleksandar
Tue Feb 19, 2008 5:42 pm
Just got back from a drive and I have a problem with the brake lights, the indicator is working, it detects well. The lights don't want to go on, actually they may blink with the brake pressed but won't work continuously. And it seems that they work only with the car started. THe last bit may be a coincidence though.
ucpsale
Tue Feb 19, 2008 6:32 pm
Try shorting the brake light pedal switch, down in the foot well. Thanks
Chris
Tue Feb 19, 2008 7:29 pm
Easiest thing to check is the switch under the brake pedal, operate it while someone is watching to see if that is the problem.
If that doesn't show up anything, check the earths for the rear lights clusters.
Tue Feb 19, 2008 8:12 pm
Sounds like a simple dud brake light switch to me. Not unusual.
Pull the connector off of the switch, and short the two pins in it together to check.
Brake lights only work with the ignition on.
Aleksandar
Tue Feb 19, 2008 9:05 pm
Ok thanks, will try that later. :)
