radio reception
markdemon
Sun Feb 17, 2008 2:16 pm
hi bods
just fitted my new lecy aerial and it works fine only problem is now my radio reception is crap much worse than the old busted 1 ive just replaced any ideas????
march109
Sun Feb 17, 2008 2:18 pm
Silly question time - but did you actually connect the ariel part of the ariel (ie the cable that feeds the head unit!), I once ired one of them up and it worked perfick everytime I strarted the radio, but never did reconnect the actual signal cable!
markdemon
Sun Feb 17, 2008 2:25 pm
yes m8 its all in where its suppose 2 be as i can get the stations but reception is shite
jcjdavis1
Sun Feb 17, 2008 3:03 pm
Hi. Bad earth?
markdemon
Sun Feb 17, 2008 3:16 pm
cant be bud ive cleaned and checked them all
Peter325iSE
Sun Feb 17, 2008 4:44 pm
Would a bad earth make much difference?
I've just fitted a new aerial to my 325i and the reception is also poor.
My aerial is fitted on the rear right wing and there is not way of seeing the condition of the metal under the wing.
Would it be possible to wrap a wire around the base of the aerial and earth that somewhere?
Peter
markdemon
Sun Feb 17, 2008 5:23 pm
thats where mine is and i was thinkin bout the same idea :)
TRANSPORTER
Mon Feb 18, 2008 5:13 pm
you might need a suppresor kit, just a box of tricks that cuts/dampens down all the electrical noise going on in the car, if memory stands right it connects to the power supply abit like an inline fuse would do, had to do this to a few of my older cars when fitting new stereos. Halfrauds should sell them no idea of the price though not that expensive.
THERE ARE AIMERS, USERS, MOTORISTS AND THEN DRIVERS
Mon Feb 18, 2008 7:29 pm
I havnt changed one for years but we used to have to tune it to the radio.
pete27577
Tue Mar 18, 2008 9:07 pm
did any one ever sort this as i have the same prob??????????????
markdemon
Tue Mar 18, 2008 9:24 pm
nope bud ive tried everthing and still no improvement :( :( :(
pete27577
Tue Mar 18, 2008 9:48 pm
me to wot can it be
Tue Mar 18, 2008 10:04 pm
What aerial are you using? And what did you replace?
markdemon
Tue Mar 18, 2008 10:22 pm
genuine bmw one :( not sure of the name,its an all black aerial,i swapped like for like except the old one was chrome
markdemon
Tue Mar 18, 2008 10:24 pm
it was a shadowline hirschmann blackmast :?
Hirschmann then, not had any problems with mine apart from the black wearing off
markdemon
Tue Mar 18, 2008 10:26 pm
lol ive got that too,just not gettin the reception i was hopein for,considering trying another head unit too see if that does anything :(
Cook318IS
Tue Mar 18, 2008 10:28 pm
Im sure that Halfrauds sell a signal booster too for radio antennas
markdemon
Tue Mar 18, 2008 10:30 pm
yeah ive tried that also slight improvement but still fades in and out as i go up and down the place
siddiqi1
BFG Zone Contributor
Tue Mar 18, 2008 11:18 pm
im getting this problem too, however didnt use an elecy aerial, just a bog standard one to fill the gap for now
being elecy, it cant be ab ad earth, im thinking either the aerial cable itself has cut somehwere, maybe near either the connector end at the radio, or that water penetration could be the culprit?
Ive kinda jsut got used to it unfortunately! :)
markdemon
Tue Mar 18, 2008 11:19 pm
yeah i just dont turn me radio on anymore,its that bad
siddiqi1
Wed Mar 19, 2008 10:14 am
shame though, one does need it for the traffic info!
mick_318is
Wed Mar 19, 2008 10:23 am
Did you check the Female socket that you plugged the new aerial into.
I had the same problem when I replaced mine. What I found was the female side of the socket had become distorted where the previous owner had pulled the plug out and the the connection to the centre pin to the conductor was broken.
Just something else to check.
**BANNED**
Wed Mar 19, 2008 2:36 pm
Does sound like you have a problem with the co-ax cable somewhere,are you sure it is properly connected at both ends?
Youth is wasted on the young.
insertnamehere
Wed Mar 19, 2008 3:08 pm
also that there's not a short between inner and outer, just one strand is enough to ruin reception - same as TV aerials (remember them kids?) :D
1977 Austin Allegro 1300
1992 FIAT Tipo 1600 (SOLD!!! 8O)
1977 MZ TS250/1 "supa-5"
1993 Cagiva Mito 125
1987 E30 318i (Daily driver for????)
1988 E30 325i (Not anymore, let down by seller...)
markdemon
Wed Mar 19, 2008 6:02 pm
yeah ive even put new plugs on the ends and still not a great improvement,just might have too fill the hole and go for a roof mounted sting,dont want too though will spoil the look of my car :(
Wed Mar 19, 2008 7:50 pm
Roof mounted?!?!!!!!
Wash your mouth out with soap and water! :)
I went digital and the signal is worse!
markdemon
Wed Mar 19, 2008 9:26 pm
i know ive just beaten my self with some birch twigs lol :eek: :eek:
