My Youtube Channel - BAD E30 - Restoration of my S38 Swapped E30 Touring and more!
Got a link to a great E30 Video, want to promote your E30 YouTube channel? Post it here.
lellis
Tue Apr 13, 2021 8:52 am
Hi, and welcome to my Youtube Channel thread. I have recently started to produce videos of my restoration processes, which go into great depth to help people understand and learn from it.
Please have a watch if you're interested! I'll post my current videos now, then update with new ones as and when. There is much more to come, Thanks!
S38 swapped E30 Touring - In Progress..
E36 318IS Coupe
E38 740i
Instagram: http://Instagram.com/bad_e30
Build Thread: viewtopic.php?f=25&t=272997
Youtube: https://www.youtube.com/c/BadE30
lellis
Tue Apr 13, 2021 8:53 am
For the people asking about how I restore my hardware using zinc plating,
This video is an in depth explanation of the whole process which I find invaluable to a restoration project.
I look to use this process during every single project, having my own kit in my workshop makes it so helpful to do however big or small of a batch to suit my likings,
E36 318IS Coupe
E38 740i
lellis
I understand this is for an e34 m5 engine, however these s38 ITB's are very similar to the s14 ITB's in the e30 m3.
This is a step by step video on the complete restoration of an s38b36 individual throttle body set.
All this work was carried out by myself with only a few new wear parts that have been replaced!
E36 318IS Coupe
E38 740i
lellis
Tue Apr 13, 2021 8:54 am
Here is the complete restoration of my s38b36 air intake, unfortunatly due to size restraints of the e30 engine bay compared to the e34, there is no room for this without modification which I did not want to do. This item is now for sale!
E36 318IS Coupe
E38 740i
lellis
Tue Apr 13, 2021 8:56 am
Here's a simple video of the disassembly of my front subframe, I will be breaking the restoration down into sub-categories to go into depth of each process!
E36 318IS Coupe
E38 740i
lellis
Tue Apr 13, 2021 8:57 am
One of my favorites, this video is of my complete restoration of a s38 alternator! Some real zinc plating bling here
E36 318IS Coupe
E38 740i
lellis
Tue Apr 13, 2021 8:59 am
As always, here is the youtube video! This is a in-depth step by step video of a complete restoration of the purple tag rack, this can be used on many other e46 and similar racks!
I made this video due to the lack of information around to help complete this task.
E36 318IS Coupe
E38 740i
lellis
Here is how I restored my s38/m30 starter motor!
With no real research into the work required before starting, I was happy with how the restoration went.
E36 318IS Coupe
E38 740i
lellis
Decided to spend my weekend giving my daily a complete interior make-over!
Very happy with the end result after a lot of work, here is a video of the whole process!
E36 318IS Coupe
E38 740i
lellis
Tue Apr 13, 2021 9:00 am
Took a break over 'winter' but back to it already! Here is my latest project.
Restoration and reinforcement of my subframe.
E36 318IS Coupe
E38 740i
lellis
Tue Apr 13, 2021 9:01 am
Continuing with my front assembly restoration, here is my front control arms.
I pressed out the old ball joints and bushes, sand blasted the arms and painted with POR15, the installed LEmforder inner and out ball joints with a powerflex poly lollipop bush. Enjoy!
E36 318IS Coupe
E38 740i
lellis
Tue Apr 13, 2021 9:02 am
Now this restoration is pretty niche, but once again, with no information on how to do the process I thought I'd film the process!
E36 318IS Coupe
E38 740i
lellis
Sun May 09, 2021 4:16 pm
For anyone who has damaged or worn out fog lights that need replacing, here’s how I refurbished mine!
Not everyone wants to use cheap depo replacements.
The video includes everything needed to help do it yourself, thanks!
E36 318IS Coupe
E38 740i
lellis
Tue May 18, 2021 11:22 pm
Here is a nice detailed video of my front strut upgrade and restoration to BC coilovers and Willwood brakes!
Plus the usual POR15 goodness, obvs..
E36 318IS Coupe
E38 740i
lellis
Mon May 09, 2022 7:40 pm
I have had a lot of interest in how I have done my underseal removal, here is the video explaining each step!
Please have a watch, I hope you enjoy it.
E36 318IS Coupe
E38 740i
fixedwheelnut
Mon May 09, 2022 8:13 pm
Epic build Liam, this is going to be the dogs danglies when it is finished :D :clap: :clap:
lellis
Fri May 13, 2022 9:42 am
Thanks Steve, I feel like I can see the end of the tunnel! Even though it looks like I am the furthest away from it..
E36 318IS Coupe
E38 740i
lellis
Mon May 23, 2022 4:24 pm
A quick video of my rear subframe restoration + reinforcement.
Using camber/toe adjustment, diff reinforcing and poly bushes!
E36 318IS Coupe
E38 740i
lellis
Tue Jun 07, 2022 9:12 am
The second part of my rear assembly series.
These original calipers were in the usual sorry state, but I have been able to get them looking fresher than out the factory
E36 318IS Coupe
E38 740i
lellis
Mon Jun 20, 2022 9:58 pm
The 3rd video to my rear assembly restoration series
The driveshafts have been a great project and a good learning curve for me.
I struggled to find much information about how to remove the axle side CV joint but there was an old thread on here which showed it was possible so I gave it a go. It turned out great and I would highly recommend others to attempt the same.
E36 318IS Coupe
E38 740i
lellis
Tue Apr 11, 2023 4:13 pm
A complete restoration of my 188mm limited slip diff video just posted on my YouTube!
This one is particularly special being a 3.15 from a z3 with extra clutch plates.
All parts and specs posted in the description for anyone interested in doing the same.
E36 318IS Coupe
E38 740i
lellis
Sun Jul 23, 2023 7:03 pm
Restoration and reinforcing of my rear trailing arms.
E36 318IS Coupe
E38 740i
lellis
Sun Jul 23, 2023 7:04 pm
Rear valance replacement including repairing all the other rust in the area (rear pockets, chassis rails etc)
E36 318IS Coupe
E38 740i
lellis
Mon Aug 21, 2023 5:51 pm
My version of the twin ear diff mounts from the e36.
E36 318IS Coupe
E38 740i
lellis
Sat Oct 21, 2023 10:10 pm
My complete underseal application process, all links to products used in the description of the video.
E36 318IS Coupe
E38 740i
lellis
Mon Jan 22, 2024 5:30 pm
My fuel system restoration and installation.
Including modifiying my vapour tank venting!
All part numbers/products used in the video description.
E36 318IS Coupe
E38 740i
lellis
Thu Jan 25, 2024 5:05 pm
The car is back on the floor!
All parts installed in this vid from 2 years worth of restoration.
E36 318IS Coupe
E38 740i
lellis
Tue Aug 13, 2024 10:03 am
My simple method to removing the sound deadening and prep for the interior respray
E36 318IS Coupe
E38 740i
lellis
Tue Aug 13, 2024 10:04 am
The DIY interior respray!
E36 318IS Coupe
E38 740i
lellis
Tue Aug 13, 2024 10:08 am
The dampening of road/drivetrain noise was a must for me. I decided to go for more than the factory, especially around the bulkhead as I don't want to install the water trap engine bay insulation.
E36 318IS Coupe
E38 740i
lellis
Something that is often overlooked during a restoration, I wanted to have a look inside and I am glad I did
E36 318IS Coupe
E38 740i
lellis
Tue Aug 13, 2024 10:12 am
I have always wanted to do the removable core/radiator support. Mainly due to the ease of access due to the size of the engine going in. I never liked the way some others did it, so I spent more time making it how I wanted.
E36 318IS Coupe
E38 740i
lellis
Mon Dec 09, 2024 9:36 am
A pretty significant update regarding the engine, it is back from the machine shop and ready for mocking up and starting the test fitting.
E36 318IS Coupe
E38 740i
lellis
Tue Apr 22, 2025 7:39 pm
Just some of the work that has been done to get the engine to fit
E36 318IS Coupe
E38 740i
lellis
Tue Apr 22, 2025 7:40 pm
Everything I have done to complete my full dry mock up
E36 318IS Coupe
E38 740i
