When I bought this car in July, I imagined I had not a pile to do to this car! But in closer inspection, I realised this car needs attention, to get on the road. She was SORN! I had decided before I saw this car I was going to buy her! I booked the MOT as i got a cancellation ( 8 week waiting list over here) My first drive of the car when I got it home, tried to clean the discs by heavy braking! The discs were done and virtually no pads left either.
So a quick purchase of a new complete set.
On liftng the car off the ground the dreaded crunch sound was heard and rust falling to the floor. The passenger side lifting jack point went into bits and pushed the floor a bit. Driver side was rusty but did not fall apart!
I wondered if this was going to fail the MOT.
A sympathetic MOT Tester (Who has a 325i) told me to fix this by next time! So happy days, I was back on the road for now!
I decided that my E30 needs to be looking a little proper as they say. I like things working. When I bought this car the rev counter, mpg indicator and the OBC2 computer screen was corroded! Front fog lights don't work! The overhead OBC had a few lights on and this bugged me! The window switch was sticky and was not working properly.
THE OBC was lighting up:
Coolant Fluid
Tailight Plate Light
Washer Fluid Sensor
Brake Light Sensor
So after the MOT I fixed the issue with the rev counter and mpg indicator a few weeks ago, Fuses! Fixed the radiator bung leak (Replaced the bung) New coolant senor, Fuel filler pipe was brittle so replaced that. Discoverd a hole in the fuel tank. (Ordered a new one to be swapped at a later date)
Washer fluid sensor light was on, I noticed the piping to the healight washers brittle! So went about replacing where it needed replaced with 6mm piping! The check valves leaked so need new ones Ordered! The twin bottle looked new but a piece of plastic that holds the wiper control unit was broken! Ordered new twin bottle! Also the bracket nut that holds it there was rusted and fell apart. NLA! Anyone got one of these brackets going spare!
The brake light sensor goes out after I put my foot on the brake! Is there a reason for doing this!
Tail light plate light sensor comes on only when the lights are on! But they are working , so I don't know why it does that! Any suggestions!
Fog lights I have not been able to get at this as I can't seem to be able to unscrews the front lense! Screws won't budge! Any reason why they dont work, please let me know!
I decided to fix the OBC2. Bought new LCD from German company called Partworks!
Looks worse than it is!
On second attempt I got it working! I hadn't tightened to the computer board togther enough! I replaced the backlight with a LED version as mine was not work right when I put it back together!
Thats as far as I have got! Hopefully in September I will get the washers workiing correctly and another light out on the overhead OBC.
Oh! I replaced the window switch too!
One other thing! The radio won't hold it's memory! Why is this! Is it to do with the immobiliser!
regards
Richard
