1990 320i Touring
kdevitt
Post Tue Mar 24, 2020 11:01 pm
Got this back from its respray just before Christmas - very happy with how it came out
Collection Day -
Lots of boring stuff done since - like new indicator lenses -
New bonnet insulation - pig of a job
... and non stop parts orders
Has had new headlights, grilles and rear lights fitted, and lots of other minor bits. Dropped it around to Coolmine Motors last week who fitted a new viscous fan and sorted a few other small problems.
ocde30
Post Wed Mar 25, 2020 9:32 am
Looks great! The new headlights really lift the look to a new level - well done.
kdevitt
Post Sat Aug 22, 2020 10:07 am
Have been using this a bit lately to try and shake off the cobwebs and see if any issues pop up. The main issue has been a horribly stiff accelerator pedal - which has been the case since I collected the car. It required significant effort to just blip the throttle, and I reckoned that some of the idling issues were related to it. Lots of links suggested that the accelerator cable would make a massive difference, I knew it would help - just didn't expect the difference to be so immense. It was a bit of a pain of a pain of a job - working in and around the pedal box always is.
I ended up using a soldering iron to melt the retaining clip after several others methods failed - the difference afterwards is night and day. Two quick vids show the difference between the old and new cables -
kdevitt
Post Wed Oct 21, 2020 8:36 am
Put this through the NCT (MOT) a few weeks ago, passed with flying colours - somewhat surprisingly - not sure why it was such a surprise given the amount of work done, but it been a while since it was done, and something trivial always crops up. Have been using it daily since, which is a pretty good way to discover all the other jobs it needs done. It actually drives very well (again - not sure why that's such a surprise) but did need some issues resolved. The main one of those was some horrendous idling - way too high, with the car shaking, poor starting, and kangarooing at light throttle (which I'm pretty certain is a clogged up TPS) .
Starting point was the ICV - cleaned it up, seemed like the internals were moving freely - and refitted. Absolutely no improvement. Decided to tick off the quick jobs - so swapped out the blue temperature sensor next. Anyway - started the car up and the revs were sitting bang on where they should be at roughly 700rpm. Idle was still very rough though.
Decided to swap out the plugs, ignition cable, rotor cap etc at this stage. The plugs were definitely past their best - or connected to a boat anchor at some stage.
Again, no real improvement, and with no ide of the history I decided to buy new injectors. Its turns out that brand new injectors from Bosch are now more or less the same price as having the old ones refurbished here - so put in an order for a set. In the meantime it was bugging me that the ICV might not be right. The Bosch original ones aren't available anywhere at the moment, and paying BMW €700 for one isn't a runner. So a spurious German one was bought from eBay which was fitted yesterday, and, the idle seemed more or less perfect ,with a tiny hint of a misfire at idle, so I'm still happy enough to be replacing the injectors.
Also went ahead with a new chip - sourced on here. Someone at the post office decided to stand on it though, so when I opened the package I was greeted with this -
Luckily I'm pretty gifted with a pair of tweezers, so I was actually able to straighten out all the pins and get it seated correctly in the ECU. I haven't spotted any significant difference as yet - but it gets good feedback, and it was cheap - so we'll see how it goes.
Otherwise it was being kept clean, most of the time.
The issues with the idle quickly returned after fitting the new ICV unfortunately, which I suppose shouldn't be totally unexpected as it wouldn't be at fault for the kangarooing which I was experiencing. It basically left the throttle position sensor, injectors and AFM as the potential issues.
The engine on this car has a different TPS to normal since it was originally in a switchable auto car - and it made it a pain to source. New ones were around €370 - whereas a standard TPS is around €150. My nightly scouring of eBay resulted in me finding a brand new Bosch one in Germany for €70 - so snapped it up as quickly as possible.
With the injectors and TPS being replaced, it was an opportune moment to do the rocker cover again. Had it powder coated originally, but the finish was beginning to bubble slightly and there was some oil weeping around the edges. Picked up a spare one and did a VHT special -
I used this a few times in the past and struggled to get a decent finish but realised the key is to load up paint like theres no tomorrow. This photo shows the drying process quite well (I applied heat!)
A sensible decision was also made to hand the car over to Xworks (him of the E30 rebuild thread on here) to fit up the bits and resolve the idling issue - Brian knows E30's inside out and is well able to diagnose issues which are beyond my ability. It was pretty good timing - the day before I was due to drop it over the idle got significantly worse, and ended up cutting out once or twice.
Anyway, firstly - and embarrassingly - I'd left a cap on one of the plugs. Wasn't specifically causing my idling issues, but probably wouldn't have helped either.
Before replacing it, Brian tested the TPS - it was failing every 10/15 times - so definitely needed to be fixed -
New injectors went in next - they look different to the originals, but are the correct spec and work fine with the M20 engine.
Two vacuum leaks were also found under the throttle body, which were fixed up. I can't imagine I'd ever have found them. A quick tidy up of the throttle body was done as well -
The car is idling perfectly now - Brian is doing a few more small jobs, but should have it back by the weekend - just need to find a space for it now that I've bought a new daily!
flybynite
Post Wed Oct 21, 2020 10:21 am
Looking good. Real shame you had to let the henna chromie go. Is it still around?
kdevitt
Post Wed Oct 21, 2020 11:05 am
flybynite wrote: ↑
Yeah I sold it to a lad I know, but it needs major work now. Its stored indoors, but moisture has gotten the better of it. It needed a full bare shell respray when I had it, which was one of the main reasons for not holding onto it. The paint job that was done on it was really awful.
Also had trouble keeping the M30 bled properly - no one seemed to be able to manage it, so constantly had the temp gauge on the wrong side of centre.
kdevitt
Post Sat Oct 24, 2020 7:50 pm
After getting the idling and running sorted - there were one or two other smaller issues that Brian looked into. The first was the water temperature not coming up to half way - I'd replaced a pretty manky looking sensor with a brand new Febi Bilstein one. Kind of applied the logic that the new one had to be reading correctly, but turns out that wasn't the case and after putting in a new BMW sensor, the temperature was reading correctly again. So the future lesson is to avoid anything other than the genuine sensors.
While the car was there, it also made sense to have him investigate the cruise control - which had stopped functioning suddenly. This was a retrofit - so theres always a concern that something was missed, or my soldering has come apart - it was a LHD loom extended for the RHD car. My own thought was that the clutch switch was acting up as the connector is not in good condition.
As always with Brian, when he's investigating an issue you know he'll be thorough with it - hence the wiring diagram on the drivers seat.
All the stalk wiring checked out fine -
And despite still not being in great condition, the clutch switch and connector were all work fine. Same went for the brake switch - which takes its feed off a space on the accessories socket behind the glove box.
Then the cruise ECU was checked - which again was working fine. Main problem with this was trying to remember where I'd actually put it so Brian knew where to look.
The only thing actually left to check was the actuator - there's a good reason I got Brian to look at this, because I never would have found the issue in a million years.
Turns out that a bad/broken solder joint on the big brown solenoid was not letting the little white gear engage with the big red gear. The red gear is the one that pulls the throttle cable on and off).
That was quickly rectified, and all was well again. Collected the car today and its running amazingly. Purple tag rack up next - the existing rack is getting worse by the day!
tha881
Post Sun Oct 25, 2020 8:43 am
This car has come along way, great choice with the kit, not much beats a tech 2 touring. Have you got any more work planned or is it nearing completion?
kdevitt
Post Sun Oct 25, 2020 9:03 am
tha881 wrote: ↑
New rack is up next as I mentioned, then ned to resolve some clunkiness going on with the gearbox Am hoping a change of oil will do the trick. Need a better ratio diff on there - will probably go with a open diff to be honest with the way prices have gone on LSD's.
Its off for a leather retrim in Bespoke Leathering once things settled down Covid wise. Needs some small cosmetic work as well for some bits I'm not happy with.
tha881
Post Sun Oct 25, 2020 9:25 am
Hopefully the oil change does the trick. The lsd prices have gone nuts, it's something I would love but cannot justify, although i have seen an affordable option from this company
https://www.racingdiffs.com/collections ... 8118294663
Ive not seen any reviews though, it seems too good to be true. The new steering rack will really liven up the car, keep up the good work.
kdevitt
Post Sun Oct 25, 2020 9:38 am
Cheers. This won't be seeing any track time, and I'm unlikely to push it enough on the public roads where the LSD would really be needed - so just can't justify the cost for scene points at the moment. Have a CRX coming out of paint soon, which I will probably use for occasional track time so the E30 doesn't need to tick that box.
My steering is getting very heavy, and the rack is making unhealthy sounds - so the purple tag upgrade will make a lot of sense. Fix whats there and improve it at the same time.
flybynite
Post Sun Oct 25, 2020 9:51 am
tha881 wrote: ↑
I think that is a kit (the bottom bits) to convert a normal LSD to a progressive one. You need an LSD to start with.
It just looks like a set of 30 degree ramps to me
kdevitt
Post Sun Nov 01, 2020 3:34 pm
Got to drive this a bit more during the week - idling & hunting issues are thankfully resolved now. Engine sound great - am curious as to whether or not I'll improve on the 15MPG I was achieving. Its possible that most of the fuel was passing out the exhaust unburnt anyway - so I'm hoping to reach the heights of 25MPG or so. In rather typical fashion - and I think I mentioned elsewhere that this car is simultaneously the best and the worst E30 I've owned - the slight steering rack issue has become what seems to be a full on steering rack failure. There's next to no assistance now, and its very notchy returning to centre, which is causing some interesting handling characteristics to emerge. So that has become a more urgent piece of work than it was previously.
Did manage to tidy up the inlet manifold this weekend though. This was initially vapour blasted - and looked excellent - but by the time I collected the car the finish has degraded. Not wanting to send it off again - I bought a tin of aluminium paint and refinished it by brush. Turned out very well - easily touched up as well if needs be.
BHadley
Post Sun Nov 01, 2020 6:07 pm
Inlet looks factory fresh, nice job!
kdevitt
Post Sun Nov 01, 2020 9:17 pm
BHadley wrote: ↑
Cheers - am happy with it alright. This was it straight after vapour blasting - the aluminium paint does a good job of matching it.
kdevitt
Post Fri Aug 25, 2023 10:43 am
Progress on this has been very slow - but this should take it up to date -
Had the car transported to Bespoke Leathering in December 2020 - strip down started quickly but work came to a shuddering halt for three reasons - firstly, a pond had developed in the back of the car. Quickly figured out the reason for this was me leaving the gutter trim piece for the sunroof out of position when I was working on the roof and waiting for new sunroof gates to arrive. Carpets were coming out anyway - so this wasn't the complete shit show it could have been.
However - the coolant in the passenger side footwell was an issue. The heater matrix had developed a leak - so John said he'd source a new one and fit it up.
The last thing was the longest to resolve - the headliner hadn't been done particularly well - it was in such poor condition than John would rather not redo it. So we needed to track down a good used headliner - which took a lot longer than expected. Also needed to source a good dash to use - again - that took quite a while.
The car is having a full retrim, new headliner, and new carpets being made.
If you're follow Bespoke Leathering on IG you've probably seen these, but they should give you a good indication of how work is progressing. Its been relatively slow but steady progress -
[video=youtube_share;VNaNUGoZ-88][/video]
[video=youtube_share;XI_hkGSQvE0][/video]
[video=youtube_share;BHHXBrHgc3E][/video]
[video=youtube_share;4E3gGkBK59E][/video]​
Further delay then caused by the sunroof crapping itself again. New cables and a repair kit were ordered - and John got it back function again, which meant the headliner could go in -
Seems like all my headliner work is getting done at the same time - appreciate these aren't the most exciting of updates! Its also potentially bad news for my liquidity with all teh cars coming towards the end of their work - but theres still a good bit to go on this before I collect it. Both cars I have in for retrims at the moment ended up having sunroof issues - pretty similar issues too. This needed new cables and a few other bits which held us up a bit - but John has been slowly working away on it. He sent on some pictures this week as the reassembly was being done. Am exceptionally happy with how this is turning out. The headliner work looks pretty flawless to me. If you peek in through the sunroof picture you'll see the doorcards are back on too.
Post Sat Aug 26, 2023 7:42 pm
Looking forward to seeing the end result, I reckon you will be paranoid about getting in it! :D
kdevitt
Post Sat Aug 26, 2023 9:51 pm
DanThe wrote: ↑
Hah - I’m more worried about PETA coming after me for the amount of leather being used for it!
Definitely looking forward to getting it back - Johns work looks top notch.
kdevitt
Post Tue Aug 29, 2023 8:11 pm
Another quick update with the headliner / roof. Don't think I covered it on here previously, but one of the jobs I did with the car was to convert the sunroof from manual to electric. Its a pretty straightforward job - but it left me with the issue of what to do with the big hole that was left in the headliner. The electric sunroof only requires a small cutout for the switch, but the manual one had a whole the size of my fist for the window mechanism to fit into. Someone suggested that the front trim piece from a saloon model would work. So managed to get my hands on one, which I loved the look of.
With a new headliner going into it, it wasn't actually necessary to keep the additional trim piece - but I like how it looked, and its not going to be something you see on most tourings - so we went ahead with trimming it.
Needless to say, John has done a cracking job with it. Actually need to buy new visors to go into it - the current ones have a small bit of slack in them - so they're drooping a bit.
kdevitt
Post Thu Feb 22, 2024 2:15 pm
Another quick update on this, but seems like its getting closer to completion now - sourcing trim pieces which still have clips intact on them has been a slight issue!
Post Thu Feb 22, 2024 2:35 pm
Looking good!
kdevitt
Post Thu Feb 22, 2024 2:43 pm
Also seemed a shame to do a full retrim, but leave the 30 year old carpets in there. So part of the ask was to create new ones - not the easiest thing to do when the originals have a moulded foam back on them. John was able to basically create a giant new overmat - transferring the heelpad over as well. The original carpets were left in place so that the foam shape was held, but the pile was cut down and these were glued on top. Any stitched seams should be in places where the seats will cover them.
kdevitt
Post Mon Apr 22, 2024 6:28 pm
Made a cameo appearance on Car SOS last week ....
fixedwheelnut
Post Wed Apr 24, 2024 11:01 pm
Beautiful Touring, looking good.
kdevitt
Post Mon Sep 09, 2024 7:31 pm
John is still making progress on the interior - the most difficult bits are out of the way now, and this was definitely the most difficult of the difficult bits... the dash. Theres been an immense amount of work thats gone into this - very happy with how its worked out. Just the seats left now - and they're one of the simpler parts as he has all the patterns already done. He's back on a few interiors for Car SOS at the moment - so won't be a whole lot longer I'm guessing.
Post Tue Sep 10, 2024 4:56 pm
Hell thats good to say the least mate !!!! :banana: :banana: :banana: :banana:
kdevitt
Post Tue Sep 10, 2024 7:16 pm
martauto wrote: ↑
Cheers, yeah its coming on well. A very slow burner - have a few projects on the go!
twenty
Post Wed Sep 11, 2024 6:16 pm
kdevitt wrote: ↑
Stunning. You really get what you pay for.
kdevitt
Post Thu Sep 12, 2024 9:41 am
twenty wrote: ↑
Cheers - yeah its definitely not a bargain basement job. Have had cheaper work done previously by other lads and its just not up to scratch - you just end up having to have it redone.
lellis
Post Tue Oct 08, 2024 11:35 am
Wow, seeing this level of interior retrim is really making me question my ideas! I haven't actually thought about what I want to do with mine.
S38 swapped E30 Touring
Currently travelling the world
Instagram: http://Instagram.com/bad_e30
Build Thread: viewtopic.php?f=25&t=272997
Youtube: https://www.youtube.com/c/BadE30
kdevitt
Post Tue Oct 08, 2024 2:59 pm
Its making me question my own ideas to be honest :D
I hadn't intended going to this level of detail with the work - but it looks so good after the respray and Tec II kit were fitted that I felt it needed a good quality job done. Similarly, I put a cheap Pioneer unit into it to at least give me some sounds - and have now paid the deposit for a guy to pop over to Bespoke and look after the audio side of things. Nothing too crazy, and nothing visible except for a Blaupunkt Frankfurt unit - but should be a good standard anyway.
Then it'll be off to our man Dan for some minor upgrades and tinkering!
Its taking quote a while to get done - but thats suiting me at the moment, have a CRX and E36 project on the go too.
kdevitt
Post Mon Dec 02, 2024 7:42 pm
Not a whole lot of progress in this post - but its the sort of thing I love - might be of interest to one or two of you. I love relatively subtle upgrades which are generally not noticeable to most people. Before the car was transported over to the UK, myself and John went through a few things that we figured were worth doing while the car was with him (some other ideas have since been discarded - E34 armrests anyone?). I've had the OEM cassette holder in previous E30's, and they work fine - but wanted something just a bit different. The E36 version of the cassette holder is a much cleaner design, and while it isn't a perfect fit for the E30 console - as you can see - its close.
With the console being trimmed in leather, it meant that it would be possible to hide any work required to make it fit.
Bottom of the cassette holder was taped up - some holes put into the console to aid adhesion for the filler.
First skim of plastic filler
Sanded back -
And the finalised version is here to view - (YT has oversaturated the colour it seems!)
[video]https://youtube.com/shorts/pCKMhJLWuxo? ... KqwzW4-3cI[/video]
Post Tue Dec 03, 2024 5:05 pm
Hell that`s good mate :clap: :clap: :clap: :clap: :clap:
Who on earth is doing the leather work ??
kdevitt
Post Tue Dec 03, 2024 5:30 pm
Cheers, its John at Bespoke Leathering - you'll have seen a lot of his work on Car SOS if you watch it
kdevitt
Post Thu Apr 10, 2025 6:05 pm
Got a rather accusatory email from John a few weeks back asking if I'd been bodging the car at some stage :D . I probably had, but this definitely wasn't my handiwork. The rear headrests are pretty easy to fit on these - have a grope around to feel the support tube, make a hole and stick it in there. This car has been through quite a few owners - some of whom are on here - so I am curious who did it! Anyway - its fair to say they skipped he part where you find the tube to fit the headrest to -
Since the headrests were fitted arseways, none of the bushings or little trim pieces were present. So, had to price them up.... just to highlight how nuts some older BMW parts have gone - these are the prices from a how-to on here a few years back
Cover (x 4) BMW part no. B52.10.8.191.245 £0.73 each
Washer (x4) BMW part no. B52.10.8.838.969 £0.19 each
Guide (x4) BMW part no. B52.20.8.132.020 £0.77 each
Total £6.76
Current prices
Cover (x 4) BMW part no. B52.10.8.191.245 €19.90 each
Washer (x4) BMW part no. B52.10.8.838.969 €19.90 each
Guide (x4) BMW part no. B52.20.8.132.020 €31.27 each
Total €284.28
Needless to say, I didn't want to pay that for some tiny plastic trims. Managed to source a full set of rear seats purely with the intention of getting the trim - mentioned it to John, and he said I'd already provided them. Obviously the car is way a long time, and I'm not getting any younger - but I have zero recollection of sending these to him. But there we are - they've got the complete set of trim bits present.
I'm still convinced they belong to someone else, but I'm not arguing over it.
So some progress -
The seat backs are actually carpeted - so these have been dyed to match the new floor carpets which were made. A day or two for these to dry off and then they all get reassembled.
