'91 318iS minor resto.. ;-)
Split_S
POR 15 junkie
Post Thu Oct 08, 2015 1:15 am
This update is for those of you still riveted to the slow progress of this eternal resto...
Sanding is progressing pretty well.. The worse part of the car is the rear pax arch..
Remember:
I had rebuilt it as best as I could...but it wasn't exactly a perfect match...
Soooo....a few million years and lots of filler later....
I have no idea how many times I had to go over this entire area...sand..prime...check..sand....aaarggg
Almost there...
Uh, no not really...
BMG
Post Thu Oct 08, 2015 1:45 am
Nice work, but if you are blocking all the primer down, isn't it worth doing it with a compressor and less tedious as no matter how it sprays out, you are flatting it back anyway ?
Also, who and what's happening with the top coat if its to go over a rattle can paint ?
Split_S
POR 15 junkie
Post Thu Oct 08, 2015 2:24 am
Well with cans no prep or cleanup is required... These new tips they have spray really well. And asking at the paint shop I wouldn't have saved any $$ by buying primer by the gallon to spray with the compressor...
Painting will be done in a paint shop by a pro. The car will be completely final primered prior to paint at the shop.
I have already bought the paint too. DuPont Chromax Pro.. Very expensive stuff but there is NEVER any money to be saved on paint IMO...
Just a few million things to do before that happens though!!
Split_S
POR 15 junkie
Post Fri Oct 09, 2015 6:10 pm
Despite the irony of having a cleaner version of the same car not 2 feet away from the car Im slaving over I just keep at it...
This rear arch is a complex fix.. Im trying to get this line right and the curvature of the arch above it... :(
Aaargh... getting there oh so slowly...
Split_S
POR 15 junkie
Post Fri Oct 09, 2015 10:18 pm
Door frames done as well...
DS rear quarter is done..
Know what?
Time to get this thing back on wheels!
bimanut
Post Sat Oct 10, 2015 12:57 am
willnz wrote:I want your rotisserie.. !!! :D
Damn handy bit of kit that I have been intending to make for decades now but never got a roundtoit :mad:
Me too!
Pictures and measurements of it would be nice :D
Split_S
POR 15 junkie
Post Sat Oct 10, 2015 1:47 pm
Ive already listed it for sale locally for the last month.. no interest yet...
I have already included info and a link to all you need to build it in my thread...
I would never do this without a rotisserie.. I spent 5 weeks under the M3 redoing the brakes/fuel/suspension without a rotisserie and it was hellish...
Split_S
POR 15 junkie
Post Sun Oct 11, 2015 5:08 pm
Well. things are getting serious..
Im at the point where its time to get the suspension back on and get this beast off the rotisserie (especially since its for sale!).. So here we go (again!)..
The M3 suspension overhaul I did last spring should make this a no brainer.. Everything is the same (except for front suspension geometry but lets not make that a big deal...)
So step one.. Front brace..reinstall...
Id prepped the front struts last year and it was pretty easy to get the brand new bearings on... Dust protection plate on first! Doh! That would be an easy one to forget...
I know youre supposed to press them in.. I very gently tapped them in and it worked fine..
Bilstein B4 shocks..wish I had put these on the M3.. the b6's are honestly best for tracking...
I also put the nut on but only loosely.. final torquing will come later...
Here is the setup with all the parts in the right order..Pure stock..old school in this age of coilovers but I like it...
Dont forget to cover the bearings.. protection is always important..
and on the inside too..
A little persuasion for the springs... dont kill yourself doing this..its dangerous as f*^k..
With the springs compressed and everything in place put on the nut and use a torque gun to torque it on.. The shaft of the shock will spin but the gun will spin the nut faster and it will all work out... you should see 3-4 rows of threading beyond the nut once done..
One down...
Done..
Nice eh?
jimbom30cab
Tech 1 freak
Post Sun Oct 11, 2015 5:13 pm
VERY Nice almost a shame to put them on a car !!
Super work, i'm a big fan
:cool: :cool:
jimmy16v
Post Mon Oct 12, 2015 5:37 pm
Wow, just read through the entire thread. Great commitment to the resto and to writing up this thread! The M3 is stunning too, spent quite a while drooling over your interior winkeye , will definitely be subscribing :D
Split_S
POR 15 junkie
Post Tue Oct 13, 2015 2:27 am
jimbom30cab wrote:VERY Nice almost a shame to put them on a car !!
:cool: :cool:
Thanks jim!! I always appreciate your comments!
jimmy16v wrote:Wow, just read through the entire thread. Great commitment to the resto and to writing up this thread! The M3 is stunning too, spent quite a while drooling over your interior winkeye , will definitely be subscribing :D
Thanks and welcome to the Zone..be careful..what we have here - it's contagious!! :wink:
jimmy16v
Post Tue Oct 13, 2015 8:48 am
Thanks very much! Oh I can relate, there's a 325i Sport sitting in my garage thats doing a good job on keeping my savings minimal.
Split_S
POR 15 junkie
Post Thu Oct 15, 2015 12:55 am
Slogging on...
Id bought new wishbones and came very close to donating them to the M3's suspension's restoration effort...but alas I had the nagging doubt in the back of my mind that maybe, just maybe I would pony up and go for the OEM aluminium ones despite the fact that I would never notice the difference either way...
I did buy a set of M3 lollipop bushings.. These have the centering holes offset or "eccentric" which has the effect of shifting the wishbone slightly towards the wheel arch which increases the caster.. Simply put: more fun in curves. :D
See..
Concentric or standard bushing...
M3 "eccentric" bushing...
I had these pressed at a BMW shop I know..They were surprisingly tough to get on..
M3 bushing installed...
Wishbone installed..
Front end bolted in... Rack and pinion is not yet installed... That will be the e36 M3 unit I havent sourced from my parts car yet... :? That will happen after the paint job...
Oh look..no more rotisserie!!
Looking nice!!
Alrighty... What's next? The rear end... My favorite thing...just ask my wife... :D :D :D
Split_S
POR 15 junkie
Post Sat Oct 17, 2015 8:26 pm
Well, this next post will be deja vu all over again...
I thought Id get creative and put the rear beam in first..without the trailing arms or diff.. I figured it would be easier than putting the whole setup in in one go like I did with the M3.. The tricky part is jacking the beam onto the large bolts - it must be lifted equally on both sides or else it binds... honestly that's the hardest part of the whole operation..
Rear beam in place...
Plates in place - the proper way...
Nicer than this remember? Shudder....
These bolts:
that go here:
are splined and the shaft they sit in is splined to. When you put them back in they may spin which would make it pretty impossible to tighten the nuts on them later.. So, grab a hammer and a punch and tap them in, not too hard but fairly firmly.. This will lock them in place, problem avoided!
My bright idea had run into a snag.. it was going to be murder to get that bolt in for the trailing arm with the fuel inlet in the way...
I decided to ignore that voice saying FORGET IT and instead tried and was then completely UNABLE to get the first trailing arm in its slots.. I hadn't anticipated that! CRAP!
So...
Here was the issue:
Solved:
Same issue on the other side! Bloody 'ell!
Aaarg..my bright idea was a waste of time!!
Hmm..maybe I can still do this without the diff in place... :)
If you do this the stupid lazy without-help way like Im trying here you will find out pretty quickly that that whole setup will not balance and will fall
off that jack in short order... Not saying THAT happened to me and that I swore like the Frenchman I am but it could happen to YOU!
knob
Post Sat Oct 17, 2015 10:54 pm
Hi Norm, I have really enjoyed reading this thread and I did the same job on my iS last weekend. I built all mine on the garage floor first including the driveshafts and then used 3 jacks, big one under the diff and 2 smaller ones under each of the trailing arms. It is stable enough to raise onto the splined bolts without to much hassle even doing it on your own. I also fitted the anti roll bar before raising it as it is a major fiddle to fit that when all the other bits are back on. The quality of your work and dedication to record it is an inspiration to us all.
Jim
Split_S
POR 15 junkie
Post Sat Oct 17, 2015 11:31 pm
Hey Jim,
Thanks for the kind words - it really helps keep me motivated especially since this is my first crack at restoring/working on a car and Im quite beside myself when Im told Im doing a good job!
As for dedication, well that's easy - the e30 simply inspires it. Its such a great car regardless of model.
As for your approach to getting the rear susp/diff in - you definitely got it right.. As you saw when I did it for the M3 - I got it right the first time too!! Go figure... :?
This time around however, I was being cheeky and a bit lazy...
I guess there's a lesson in humility in all this somewhere.. maybe... :D
Lots more to come... 8)
cheers,
Norm
Split_S
POR 15 junkie
Post Mon Oct 19, 2015 5:46 pm
I finally bowed to the inevitable and decided to do it the right way (as Jim kindly pointed out).. I pulled my diff out of hibernation, off the shelf where it had been sitting for over a year... Much to my disappointment light surface rust had started to poke thru the black paint.. I HAD NOT Por 15'd this one (incredible but true) as it had been painted by the transmission shop.. Soooo..guess what? Yup... Por 15'd it and then got back to getting the rear suspension in...
Used two jacks and my son and his friend.. MUCH EASIER!
Amazingly I remembered to put in the rear sway bar...unfortunately only AFTER I had everything bolted in... :cry:
Im occasionally an idiot what can I say....
Split_S
POR 15 junkie
Post Mon Oct 19, 2015 6:01 pm
NEXT!
Here is the stock setup with ALL the pieces you need in the order you need them.. Very easy thing for the DIYer... Get the reinforcement plate (the brass looking one). They are fairly cheap and strengthen the whole setup.. Plus they look the cat's meow!
I also ordered the plastic sleeves and was a wee bit confused how they fit.. This is how.. That ring fits on the shaft and you slide the plastic sleeve onto it....
I know, I know: I am a genius... :roll:
I started by getting the springs in... Ive fitted the disks only to get the wheels on.. I will be tackling the brakes later this winter..
This was kinda tricky as the car weighs almost nothing... So I threw in the wheels in the back "seat" to get some weight in there.. This made it easier to jack up the trailing arm to connect up the dampener..
Sliding her in...
Loosely screwed in...
Closeup of the proper setup.. (nut is NOT torqued for now..)
Done!!
I AM a SUPERHERO!
Uh.. kinda minor superhero.... ok, it just feels good you know?
Jesus325iTouring
Frog freak !
Frog freak !
Post Mon Oct 19, 2015 7:02 pm
Still showing your car who is Boss, top man :D
KW355
Post Mon Oct 19, 2015 7:42 pm
A great read, I am planning a rear suspension rebuild over winter so this has been a great help. :D
Split_S
POR 15 junkie
Post Wed Oct 21, 2015 12:56 pm
Thanks Gents...
Soldiering on...
With the suspension ready to accept wheels I wanted to finish up the bodywork before I would have to bend over too much and put out my back... :D
At this point it was a lot of finicky touches that were required...
Damn rear quarter too...
Oops, forgot I have the rear panel to sort too... :(
Thats a bit better!
Almost kinda perfect...not really...
Right.. I only did one of these didn't I??
This one had more dents to sort than the first unfortunately..
Rear quarter complete... :D
DS rear quarter as well.. Im pleased with it...
At this point I took some time and hauled out the ugly bottlecap wheels that came with #2.. It was time to get wheels back on her for the first time in over 2 years!
Im pretty chuffed honestly but...
there's still work to do... :roll:
Door done..
Rear done...
Parts done...
Im done!!
hennared323i
Post Wed Oct 21, 2015 1:15 pm
Great work there
Yeti
Post Fri Oct 23, 2015 11:45 pm
great work dude keep it up :)
Gert_8
Post Sat Oct 24, 2015 11:18 am
Haven't you finished this yet?!! ....
:D :D
appletree
Post Sun Oct 25, 2015 8:42 pm
Your doing an awesome job! :D
Split_S
POR 15 junkie
Post Mon Oct 26, 2015 10:05 pm
Thanks gents! I can almost see the tunnel where at some point once in it, I will see the light at the end of it... :D
Next up: PAINT!!
Split_S
POR 15 junkie
Post Wed Oct 28, 2015 6:51 pm
Oct 24th, 6:00am...
The big day has arrived...
My brother's neighbour used to work in a paint shop but has since given that up and started a towing business.. How convenient for me!!
His old boss let him rent the booth on the weekend.. We were alone and I got to help out.. Fantastic!
In the shop..
Parts went in first... Car still needed some final taping up..
Here's the booth.. All parts and car were given one last final light primer coat.. I would be stuck outside during the actual painting...
Here we go!!
Guess the color and win a prize!!
Gert_8
Post Wed Oct 28, 2015 7:01 pm
Red?
Split_S
POR 15 junkie
Post Wed Oct 28, 2015 10:38 pm
BMW color code 138 to be exact...
Cinnabar Red... an e30 M3 color...
All parts completed... Clearcoat was next and really made the color pop...
Bringing the first batch home...
You know, Im starting to think I might actually finish this thing!!
Gert_8
Post Wed Oct 28, 2015 10:48 pm
Oi, where's my prize?!! :evil:
Split_S
POR 15 junkie
Post Wed Oct 28, 2015 11:10 pm
Your prize?
That last post was just for you Gert... :D
Gert_8
Post Thu Oct 29, 2015 10:34 am
I accept! Thank you. :D
What a fantastic job!
hennared323i
Post Thu Oct 29, 2015 12:18 pm
:rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock:
:bow:
:notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
Epic Stuff Mr S
jimbom30cab
Tech 1 freak
Post Thu Oct 29, 2015 12:28 pm
Looking absolutley magic
Nice one :)
