e30 316i sedan restoration and some upgrades from Bulgaria
steffgang
Post Sat Oct 26, 2024 4:58 pm
DanThe wrote: ↑
Fri Oct 25, 2024 8:04 pm
Great work!
Loving the exhaust :D
Thanks! I fully agree on the exhaust - looks even better in person.
Unfortunately though - it doesn't fit :roll: :
That was a really nasty surprise that left us quite confused. I think I got the root-cause of how it happened. As I was refreshing this thread and collecting and reviewing the pics I did notice that on the pics from the exhaust fabricator the used engine bushes are the taller e34 ones while I am using the e30 M20 ones. Pictures also confirmed that I didn't sent him the bushes with the mounts and most likely miscommunicated what bush is used since I have set of both e30 and e34 bushes around and have forgotten what I did use due to the long periods between updates. So there you have it proven - if you prolong you put yourself through more trouble...
While I was contemplating on how it happened Yordan went on and got that rubbing runner chopped and reshaped:
And had the engine back in to confirm fitment:
Very very happy to see this - he finished it just yesterday evening and I only have the pics for now. What follows is still tedious though - engine out again, exhaust manifold removal, welding, shielding it in heat tape, assembly with yet another new gasket and then hopefully the engine can go back in for good.
So that is exactly where the project is at this point in time. I will do my best to put the updates as they come for my own best - this is indeed a good way to keep record and not forget things.
steffgang
Post Fri Jan 17, 2025 12:27 pm
Progress has been ongoing with Yordan not getting much help from my end and he has slowly been realizing this is a harder job than estimated plus I've been asking all sorts of extra stuff being added since he is on it and he is indeed doing many great additions for the e30s some of which he offers commercially too.
There is one thing he pushed on me though and I think it went well on my end:
I sprayed it over with this - https://thermotec.com/hi-heat-coating-spray-black/
And I made sure I hit Yordan's deadline on this as he was getting quite furious on all crap I left behind and forget and he kept finding little by little... mostly lost bolts, etc. The one particular thing that got him nuts was the discovery that gearbox linkage I had been running before with the m40 and that same gearbox will not work. Seems I never actually connected that thing to confirm all is good and it turned out that despite my extreme engine furthest back position the M40 must have been sitting ~1cm further back (what a disappointment 8O ) essentially making the linkage I had useless... With the m40 and the 6 speed I've been using an unmodified base out of a 4pot e90 diesel with a slightly shortened linkage rod. Now that base turned out shorter than required and I brought to Yordan a e90 4pot petrol linkage which is much longer than the diesel on but mates better to the gearbox as it is the linkage for that gearbox while the diesel one is used with the GS6-37dz. Anyhow he shortened the damn thing only to discover yet another issue - one he assembled the whole thing the gear leaver hanged some 15 degrees towards the right seat indicating that there is something wrong with the engine and gearbox position. After some thinkering we agreed that my engine mounts are putting the engine slightly to the left and making the whole assembly twist leftwise thus pushing the lever base slightly rightwise causing the observed lever tilt to the right:
Solution chosen at this point in time was not to touch the mounts as engine is already in and they are painted and all plus we have zero opportunity to push the engine to the right due to the exhaust manifold minimal gap... So:
And all went at center. I hope this will not cause further troubles like drive shaft vibration, etc.
steffgang
Post Fri Jan 17, 2025 8:27 pm
Yordan pushed without much hassle the cooling connections, pipes and hoses:
Fixed the dipstick:
Did some welding on the steering line that I still don't quite understand the path of but it shall go from the rack to the right side where the pump is mated with the water pump:
And while in there added some essential additions:
Brake booster and pump out of e90 (seems to be an already popular mod that I wasn't aware of):
And a really nice solid steering column to rack linkage that he fabricates and offers at a very reasonable price:
steffgang
Post Fri Jan 17, 2025 9:01 pm
The intake has been a main focus most of the time. He managed to find a neat solution for the linkage:
On that last shot you can see also the oil temp and pressure sensor mounted and the already painted coolant piping as well as the engine wiring taking shape.
steffgang
Post Thu Jan 23, 2025 10:55 pm
Yordan was sick for few days and had to stay home. He got some quick tryout on the intake:
and within the same day also ran CFD:
Then few days later he sent over these:
Parallel to this he sorted out the engine harness and was preparing for a first start of the engine. And then on the next day he had it started for the first time 4 years later:
https://youtu.be/ckHhw048zNE
https://youtu.be/icbn8wp8Wfc
steffgang
Post Thu Jan 23, 2025 11:14 pm
I already got the chance to take a spin in it while he was doing some rough initial mapping:
So happy to get to this point!
I want to mention that we've been getting a lot of help from Daniel of https://www.elementperformance.co.uk/ who is helping with key points on setting the triggers and getting Vanoses run as he is already using EMU Black on a 320si and pursuing WTCC power figures.
We used Daniel's printed locking tool for the engine timing setup after I purchased a set that was supposed to be compatible, but is not. Daniel's tool is the only one we've been able to find and we tried the BMW dealership as well with zero luck.
The car has surprisingly few issues besides not nowhere near being mapped, but still drivable. I am extremely happy to report that my Frankenstein oil pan is easily getting 4.5l of oil plenty before the dipstick hole level and we actually get a maximum reading on that unmodified m40 stick at the 4.5l mark. Biggest issue so far is that brakes are not power assisted at all and ICV is not able to get us at decent idle rpms. Likely the reason is that the vacuum rail connections to the ITBs are way too thin @4mm inside diameter - plan is to get them up to 10mm following the size on the S85 rail to ITBs. Apparently the printed intake is not of the proper material so far and as much as I like the colors of it (which are a complete random based on filament the print guy has available) we can have them with the actual material we have to use.
Post Fri Jan 24, 2025 7:23 pm
Excellent updates, great to see something other than cupholders being made on a 3D printer! :lol:
steffgang
Post Sun Sep 28, 2025 12:36 pm
Long time no post, but this time it is because I've been busy driving and enjoying the thing ;)
Its state is still rough and far from it being half decent and presentable, but fact it is been on the road this whole summer meant a lot of fun and gave opportunity for me to continue its development by my own.
Car completed its stay with Yordan after receiving a final assembly of his 3D printed intake in carbon filled nylon. It totally surpassed my expectations on appearance:
This certainly is not a flashy carbon fiber intake like the stunning one from Daniel of https://www.elementperformance.co.uk/ but at the same time has a functional appeal in my eyes and 6 months later looks exactly the same and feels strong and durable.
Car got tuned and unfortunately, but not unexpectedly the power rating is far from anything inspiring:
Max power comes at only 6000rpm and is ~ 163hp at the wheels (less than the 320si stock rating, yes) with quite an early and flat torque curve (183NM @ 3800rpm). Most likely this means the runners are too long and we plan a change in the trumpets only hoping this will shift the torque curve further right as well as the max power past 7000rpm.
So the dyno results were a disappointment, but hey car is drivable and quite pleasant with current torque curve so we moved per plan focusing on driving it and proving reliability and fixing any issues.
Biggest immediate issue I needed to resolve was the interference of the closely fitted engine against everything in the bay. The stock m20 rubber mounts were to soft allowing for dings into the engine bay at the exhaust manifold side and into the rack as the pan is quite tightly wrapped around it in pursuit of the lowest engine position possible. I shaved that pointy thing off the rack;
and did several tests adding shims under the right mount to eliminate the manifold touching the frame rail only to find out that the movement the stock mounts allow is too much for the tight fit I have everywhere at this point. I did a research on stiffer mounts and went through two iterations:
The first set I tried is at the top of the picture. It is stiffer rubber, but the design allows near zero side flex and a very limited vertical play resulting in zero interference problems, but results in very strong engine vibrations and noise transfer to the cabin. Probably great for track, but unbearable on the road.
Second set I tried is at the bottom and it is again of harder rubber but with the OEM design. These reduced noise and vibrations to much much bearable levels, but still do not allow any interference in the bay so I stick to them, but am looking at reducing noise inside further through interior dampening, etc and might also try adding back the original engine shock:
Need to figure out the mounting point at the engine side, but I suspect this shock will be too soft to remove the much harder vibrations compared to the OEM mounts. Will post further on that...
Many small fixes were of course done as well like changing thermostat, fixing some oil leaks and what not. Worth mentioning change of the diff to a 3.73 ratio LSD and new half shafts was the second big improvement on the car after the engine shocks as rattle from rear end was significant and with the 4.44 ratio diff my cruise mode was 5500rpm @ 140kmh :roll:
Oh did I mention the gold foil :cool:
That engine sits looow:
On the interior side I am experimenting on the seating. I love sitting very low and find the Recaro LS worse in this aspect than the sport seats, but they are too high to my taste as well tbh. I have thrown in a filthy Recaro Speed borrowed from a friend mounted directly through cheap aftermarket rails with no space to the floor to even mount the rails leaver:
Love this low position, but I am not sure that is a seat that looks and fits well in a sedan. It suits coupes much better for sure:
The reclining control knob also hits the b pillar, but good thing is it can relocate to the inner side and there is enough space for it against the tunnel. Still feels/looks odd though. Any suggestions on the seating are welcomed.
I also lowered the steering wheel and with the new position the 370mm wheel feels too big so I borrowed a 350mm Momo from Yordan that feels just in place:
Car did some decent mileage this summer (can't tell how much as my odo is jammed...) including a 600km trip around the mountains in the summer heat. No signs yet of the expected engine block issue, but that is an inevitable destiny so I will be in a rebuild and next stage improvements prep for sure. So far it is a great ride and is coming closer and closer to my ultimate goal. I do need to squeeze out of it some decent top end power and I am sure this will happen too. Balance feels exceptionally good. I haven't put it on scales so far and I need to check and fix alignment still, but the light front is there and is what kept me in the 4pot camp for sure. Induction noise is great, but that stock heavy flywheel needs to go.
Random pics:
I should have probably gotten a black oil cooler:
