Sanchez
Big step there, well done. Bet your getting excited, will you sleep tonight?
CHR1S1990
Nothing better than a well sorted m20! Good work
the round plug TPS of an auto have the standard on/off e30 TPS switch, and an inbuilt potentiometer for autos. Dont go losing it when you swap over to the manual TPS as these are what's needed for megasquirt/vems etc.
http://www.ebay.co.uk/itm/BMW-E30-E36-E ... 3cc011635f
CHR1S1990 wrote:Nothing better than a well sorted m20! Good work![]()
No megasquirt here, Simon ain't stupid and he likes a car that starts and works !
CHR1S1990
nothing wrong with megasquirt if you know what you're doing
How much was the genuine headgasket Si ?
Mine is leaking oil exactly where you describe
and am planning on tackling it very soon
CHR1S1990 wrote:nothing wrong with megasquirt if you know what you're doing
Going by most of the megasquirt turds I have come across, most installers don't
tonybtonyb
Excellent work
A 164 ECU is a 325i one, alas it is the early version of Motronic 1.3 with the twin PCBs, so not easy to chip. You're better off swapping it for a later 173/380 single-PCB M1.3 ECU - a straight plug & play swap.Simon13 wrote:Its like a slug but i reckon alot of that is to do with this...............
My educated guess is this is a 320 ECU as its no 325i one! Another safety tactic pete?!
Out ya bastard. As said it shouldn't be a slug as its a 6E 2 donk. A BBR starchip will get it moving nicely when it goes back in
Alternatively, any of the later six-pot ECUs (172, 179, 381) will also work, if you fit a suitable chip.
Speedtouch wrote:A 164 ECU is a 325i one, alas it is the early version of Motronic 1.3 with the twin PCBs, so not easy to chip. You're better off swapping it for a 173 - a straight plug & play swap.Simon13 wrote:Its like a slug but i reckon alot of that is to do with this...............
Thank you Maurice, my innocence has been proven and my repution remains intact !
All I chawed was the minty foglight, oh and the tools and the mint spare and I couldn't let a eastern European manual worker have the rampant Bosch silvertop , tak tak !
glenn
- Engine Transplant Services
another good picture / write-up 'athon.
epic amount of pics on your threads si. you must be for ever wiping
your hands clean to use the camera.
Dezzy
- CR24v it's a lifestyle
Great write up as always!
It must take you twice the time to get all the pic's. I'm glad you do though!
Lovely looking engine build - look forward to seeing it in pride of place...
I think the headgasket was about £90 Rob
As always kind and helpful replies! This will only be worth it if it makes the power, needs to be a quick'un i hope.
glenn
what are you hoping to see si?Simon13 wrote: This will only be worth it if it makes the power, needs to be a quick'un i hope.
Stock power would be nice. If it does what it should i'll be happy, so 210bhp and 213lbs will do me. The lighter fly and balanced bottom end will make it nicer to drive. Who knows the head work might yield a bit more? Or less we shall see.
No rain tomorrow please!
m_jermyn
Hey Simon,
Great work mate, brings back fond memories
fingers crossed for you..
Its all in the run in.
Thats going to be one sleeper.
csl
Nice work Simon.
I dont know where you get the time for all this engine play!
Intresting read and a few steps closer for this car.
Well its in but it won't start. I seem to have no spark which is confusing me a bit as when i first went to start it did.
Frustrating but probably something simple.
Theres nothing fancy needing to be done when binning the autoness? I've unplugged the inhibitor part so it cranks over now.
Fuel is there. I'll get there just not today probably!
i appear to have the vibration damper on 180 out. So that would explain it. I'll swap it in the moring and see how i get on.
And there is spark i just couldn't see it!
vib damper/ bottom pulley can only go on one way Si, the inhibitor only stops the starter circuit so if it's cranking it's cool
have you plugged the CPS into the pulse plug try swappping them over ?
no that was another issue with the inhibitor. It won't start now.
I know it can only go on 1 way! but i must of F**ked it up it can be the only answer
Si. Check that rotor disc as well. You never know. It could happen twice....
No checked that! i've re checked the timing which was ok, and re done the crank pulley as i had it on wrong. So thats right. I've got enough working M20's to check with!
Still won't go. Going to comp test it. I need someone else who knows their onions to maybe re check what i've done. Its frustrating but i guess you can't do this work and it all goes 100%. Re comissioning an engine thats been in bits for 6 years!
must be something simple, whats it not doing si ? you got spark and fuel ?
both appear to present.
Is it worth trying another crank sensor?
Theo
You've probably just fitted something backwards mate.
Try a few drops of fuel fed in through the spark plug holes...
if anything there is too much fuel. I've done a comp test to be sure and its got loads of compression between 180PSI to 200PSI accross the board.
I've tried a crank sensor. But the thing is i've used the sensor and engine loom off the bronzit which was a working car. I was going to try a dab of oil down each bore to help the comp on start up but it looks like it doesn't need it.
Its going to be something silly it always is! It would be too easy if it all went well
Not using 6-year old fuel in the tank, I hope?
- Homo Hair
Fuel lines the right way...?
Gotta be something daft as you say!
no fuel is fresh, all i get is the odd backfire. Its got to be timing, with spark and fuel there. I'll have to re re check everything again. Thats all it can be
have you got the fuel lines on the right way around Si ? IIRC the top line coming up the inner wing feeds the rail, the regulator is connected to the bottom pipe on the inner wing
worth checking, I always get them wrong
they're right the old engine had the older style fuel rail where the stub is the bulkhead side of the engine. So i had to fit a shorter bit of pipe for the rail which makes me think that it right
I did swap the FPR for another as that came with the inlet from the scrappy. The only thing i could think of that wasn't from a working car. Just seems to have helped with some more backfires. Its almost like your engine Trevor!
