M52 b30 stroker rebuild back on the road
Fri Oct 08, 2010 11:24 pm
it has a full twin pipe 3 piece set up steve,
i think i've bought a remus back box but waiting on post details.
i think fitting the parts i had from the buy up will work re the m20 box with the diff should give better mpg return and the 6.6 kg fly will help it sprint? against the m42 box,mine crunches at 6.5k rpm in 2nd shift.
pics of the afm doo-dad en route lads when i get the chance.
Dezzy
CR24v it's a lifestyle
Fri Oct 08, 2010 11:31 pm
If it a 3 pin plug on the same loom as the afm it's off the trottlebody body warmer thing and not used mate.
Fri Oct 08, 2010 11:33 pm
mick . i have just fitted a scorpion middle box and rear silencer,as per Dan's recomendation it sounds absolutelyfookinglutely awesome
very very council.... but worthy ! :D
Fri Oct 08, 2010 11:58 pm
can i just fire the biatch up first,
slowley 's catch monkey,the finer tuning and oem councilness is evolving in a big wave of 24v righteousness brothers!
Sat Oct 09, 2010 7:05 pm
L@@k what Lee Parks found
http://www.e30zone.net/modules.php?name ... c&t=104589
it's a small world :D
leeparkes
Sat Oct 09, 2010 10:48 pm
Have you pm'd him? he might be able to throw some info on what the engine came out of and history, mileage, etc....
In the thread he mentioned something about bodging an M20 water pump with the M50 one :?
If i was putting this engine into an E30 i would consider modding the gearbox support more to lower it a tad as when i cut the tunnel open (when it was pishing down with rain) to undo the prop etc i did notice the gearbox was a bit too close to the top of the tunnel for comfort. You could put spacers in between where it bolts to the shell.
It will work but im sure the other side needs to be modded too to keep the prop straight
Im sure i have a pic somewhere in my stash where i peeled the tunnel back showing what i mean about being close, ill be back :)
Sat Oct 09, 2010 10:57 pm
I believe most M20 box modders bash the tunnel with a block of wood and sledge for clearance :eek:
Sat Oct 09, 2010 10:58 pm
DanThe wrote:I believe most M20 box modders bash the tunnel with a block of wood and sledge for clearance :eek:
Typical m20 owner :D :D
leeparkes
Sat Oct 09, 2010 11:00 pm
Extreme tunnel hacking :D
You can just see how close it is on the edge of the pic.
Edit: you can see in the pic where with the prop bolts undone there's a gap at the top where the prop is being pushed up.
Sat Oct 09, 2010 11:01 pm
Lovely piece of custom mod 8O
Sat Oct 09, 2010 11:16 pm
that looks like vibration right there!
my m42 box crunches in 2nd over 6k rpm?
i may still go with the m20 box and a spacer or two.
i'll look into pm'ing him tomorrow if he's about.
these are only small issues i'm sure i'll fettle it proper like.
now the pro's are looking 8)
Sat Oct 09, 2010 11:21 pm
magpie wrote: my m42 box crunches in 2nd over 6k rpm?
You need to use the clutch pedal Mick, it's the one on the left.
Sun Oct 10, 2010 11:11 am
what about using a dirty 6 box mick ?
Sun Oct 10, 2010 11:20 am
e30topless wrote:what about using a dirty 6 box mick ?
good idea steve,so what's involved this way?
what box is in yours m8?
do you still have that m42 box??
leeparkes
Sun Oct 10, 2010 1:04 pm
E36 will be a direct 5th gear box so you will need a diff around a 3.25 ratio, ive heard M40 boxes can be used :?:
Cook318IS
Sun Oct 10, 2010 1:10 pm
you can use an m40 box. I used one when i had my m50 in my e30, then changed to the e36 328i box when the m52 went in.
Sun Oct 10, 2010 1:34 pm
i have a good m40 box i can use,what prop and diff do i need then.
i have a 3.64 diff a m20 2.5 prop,also an m42 prop but no m40 prop??
here's the diff,it's just an open one for now.
Dezzy
Sun Oct 10, 2010 1:45 pm
My setup is
M50 gearbox
M50 prop (e30 centre bearing)
M50 gearlever bracket (z3 leaver)
M20 lightened flywheel and clutch release bearing and M50 slave.
Diff you need 3.15 -3.4ish :D
Dezzy
Sun Oct 10, 2010 1:48 pm
Yeh m40 boxes can be used
M40 box you will need 320 prop and gearleaver bracket with M20 clutch.
I have a really low milage M10 box here but not sure if they work?
Sun Oct 10, 2010 2:01 pm
i had a 320 prop and gear linkage but sold them :roll:
if i use the m40 box what mounts are deeded?
Cook318IS
Sun Oct 10, 2010 2:07 pm
you use the standard gearbox mounts for the m40 box :thumb: the modded gearbox cross member will be no use with the m40 box so use the standard one already on the car :) 3.64 diff will be ok, but a 3.91 will be better suited to traffic light grand prixs
monkey
Sun Oct 10, 2010 2:16 pm
and a 3.73 lsd with m42 g/box i have found is a good all-rounder .
Sun Oct 10, 2010 3:13 pm
looks like i'll use the m40 box as i know it's a good one.
Tue Oct 12, 2010 7:23 pm
i've needed one of these for a while and got a right result with this one cost wise,only ever used once winkeye
that'll do nicely :D
Dezzy wrote:Yeh m40 boxes can be used
sourced a 320 prop and gear selector,just waiting for delivery.
can i use the m40/m42 clutch i have atm in the car?
Cook318IS
Tue Oct 12, 2010 7:29 pm
a pink engine crane? this is a 24v engine conversion magpie not a poofy m30!! :P
If you use the m20 flywheel use a m20 clutch (ive not heard of people using m42 clutches on these)
Dezzy
Tue Oct 12, 2010 7:30 pm
Sachs M20 clutch kit would be my advice mate especially with the stick you give it :mad:
Tue Oct 12, 2010 7:35 pm
maybe i have an m20 clutch with the m20 fly i have,it's getting :mad:
the hoist is bright red just a bad pic.
wouldn't touch a m30 :D
Is that a brilliant red engine crane then? :)
Tue Oct 12, 2010 7:39 pm
DanThe wrote:Is that a brilliant red engine crane then? :)
just needs a mop every 6-weeks :snigger:
leeparkes
Wed Oct 13, 2010 5:29 pm
That pink crane hasnt got the balls to lift an M30 :D
Wed Oct 13, 2010 7:10 pm
leeparkes wrote:That pink crane hasnt got the balls to lift an M30 :D
that's what i meant [wouldn't touch an m30] :P
had look at the donk today and have a few pics and 'q's as i'm new to this malarky :D
this is the part that was poked through a cut-out in the pass head light backing cover?
all the added wires ive found go to these extra relays
and wired to this green wire.
all this lot is to do with the elec fan and temp trigger i think.
m20 fly and clutch,not sure how heavy it is yet,i hope it's lightened winkeye
a message from Lee [to the fan] that seems Geordie proof :D
erm,wtf is this?
and this :?
found where the blow was coming from.
what's the part on the left?
thanks for any help :D
Wed Oct 13, 2010 7:16 pm
Carbon canister thingamy.. Not needed but leave it plugged in out the way
Wed Oct 13, 2010 7:17 pm
Lambda plug?
Wed Oct 13, 2010 7:18 pm
thanks Jonno :D
'Image
E36 heater valve.. Not needed
