Help please
Off topic, non E30 chat.
Post Wed Jan 23, 2019 5:24 pm
https://www.ebay.co.uk/itm/PROFESSIONAL ... 2749.l2649
I bought this and it all seems good but how do I use this and what to use compound wise, bearing in mind all I require is a bloody good finish at the end of the day.
I have some t-cut and a tin of "colinax ?"
Cheers Mart. :cool: :cool:
HartgeH27
Post Wed Jan 23, 2019 6:09 pm
Practice on some scrap bodywork. There are various cutting compounds which are various grades. When initially starting out, have a spray water bottle, add the compound to the buffer, spray a good quantity of water and then work the area with the compound, Buff off with a good quality clean cloth.
flybynite
Post Wed Jan 23, 2019 9:11 pm
Don't use anything like t-cut, 8O it has ammonia and is far too aggressive to use with a mop. you will burn the paint.
You need something gentler, without ammonia (you can tell from the smell) Farecla do most of what I have always used
And as said above practice first, gently does it and lots of water. not a job when it is cold as it goes everywhere
