Cabriolet rear side windows job lot
E30 related Items advertised on eBay, Pistonheads, and Other External Ads
sweep
Post Tue Dec 04, 2018 2:37 pm
Gert_8
Post Mon Dec 10, 2018 3:07 pm
Hi Sweep, I’m after one of these. It’s the black pillar bit.
Are these attached to the rear glass? If so, can they be removed or do I have to buy the glass and post together?
If you’re able to supply one in good condition with the brushing attached at the seal, then could you let me have a price please, posted.
Gert_8
Sorry, forgot to mention, it’s for the driver’s side.
sweep
Post Mon Dec 10, 2018 6:36 pm
Fits on the leading edge of the glass has a triangle rubber section at the bottom?
Gert_8
Post Mon Dec 10, 2018 8:54 pm
Hi. I have never really looked to see if it has a triangular rubber section at the bottom. Here’s another pic of the part I’m after. - black pillar section that fits on the leading edge of the rear glass piece.
You are probably talking about the right thing. If you notice the brush material is missing off mine and My OCD is kicking in to replace it.
Is it an easy process to remove and refit?
Thanks 😄
Sorry the image isn’t the right way up - it is on my pc and phone. The new system is turning it though 90 degrees...
